Extended Travel Upper Control Arms for Toyota 4WD
nitro-gear
Supporting Sponsor - Differential & Axle Parts
Nitro is now offering UCA's for several Toyota models including 100/200 Series Land Cruisers, Lexus GX, FJ Cruiser, 4Runner, 2015+ Tacoma.
Here's some details that we think makes them the best UCA's for your Toyota.
  • To solve the extreme ball joint angle of the stock arms the ball-joint cup is clocked to run level on vehicles with 2-3" additional ride height.
  • With the proper shock setup, this allows up to 50% increase in down travel over OE/Aftermarket suspension kits that use OE length shocks. (we offer these)
Features:
  • The arms are 100% BOLT-ON
  • Heavy Duty Grease-able Sealed ball joint offers higher misalignment than OEM, and lasts much longer than uniball type arms, and no squeaks!
  • Removable Billet ball joint Top Cap
  • OEM style Rubber bushings for lower maintenance, quieter, less vibration and no squeaks!- Heavy wall tubular design provides more strength versus the flimsy OEM stamped steel arms.
  • Lower profile than OE, thus providing additional clearance for larger tires, and/or larger/ longer shocks.
  • 3 Degrees additional caster.
  • Will work on stock height vehicles as well.
On our website now!
nitro-gear
Available for nearly every late model Toyota 4WD! No more squeaky uni-balls! Finally regain the proper caster and long travel for longer shocks.
Randy Towles
