whatcharterboat
Hi . Was keen to get a few views on winches in a thread here. I know there is a dedicated thread section for recovery gear but I thought it might be good to hear from those with trucks of a 6 ton GVM and over what they think rather than just what Jeep/Cruiser/F Truck guy might use. Certainly no offense intended there. Just that big trucks require very different consideration.
What brought this about is that a guy with a RTW camper we're working on at the moment wants me to fit a 16,500lb Warn winch. He also wants it to be removable so that he can mount it on the rear or even rig it to pull from the side in the event of a roll over. It's an FG84 and will possibly run close to max GVM of 6 ton.
OK now what frightens me is the rated current draw of 500 plus amps at 12 volts and the fact that the cables will have to run from one end of the truck to the other. Say 6 metres or there abouts. Add in some thermal runaway and you are talking serious current and lots of copper to cope with it and the voltage drop over that distance. Also the biggest Anderson plugs I can find so that it will be removable are 350amp so they'll have to be doubled up.
Not to mention the weight of the thing with the bracket. Imagine the weight of a removable bracket rated at 16,500lbs alone. It will be a heavy thing to cart around. Probably close to 90 kgs combined.
The biggest electric winches I've ever fitted were 12000lb on the NPS's which are 24volt so the current is half for the same pulling capacity. With the 12volt trucks and double the current, hydraulic or electric hydraulic is surely a better option. You don't get the same thermal runaway caused by excessive current with an electric hydraulic setup as the stall effectively happens from oil by pass. Also you only need one hydraulic power pack which can be used for an extra winch, stabilizing legs, lifting rams for wheels or bikes, or anything you can think of. Imagine a hydraulic hi lift. I want one.
PTO power is even more usable but with the need for the motor to run. Not much good to you if the truck's lying on it's side. Some say "Not much good if you swamp your engine in a creek either!!" Well don't forget that most electric winches aren't sealed anywhere near as well as they should be and will need to be pulled down anyway if they're submerged. A high mounted electric power pack will run a submerged hydraulic winch for as long as you like. I used to work with ROV's. Hydraulics form the basis of propulsion for these things at the bottom of the ocean so I don't think you would ever need to worry about one in a creek. It's the electric solenoids on the valve banks that would need to be protected. Still no problem. Most are well sealed anyway.
Cost I suppose is the bottom line. Hydraulics are not cheap to set up but then replacing batteries and alternators would be painful too. Actually on that point >>> does anyone disconnect the alternators when winching. Something we've done as a failsafe before so that the current or rather load isn't transferred to the alternator once the batteries are sucked dry? Also I suppose the size of the alternator would need to be considered. If you have excessive current and hence heat then I imagine you only be able to run the thing for a minute or so and then let it cool and recharge a little. Wow the mind boggles. Bigger alternator??? Amp meter?? Running on the house batteries. How many cranking amps will they give anyway??
Really keen to hear from everyones experience on this. You can tell I'm not a fan of big electric winches. Doing another one soon too with a 12v electric 12000lb 'er but he will have a 200amp 12v DC diesel power unit along with the Fuso alternator so I think the load on the batteries will be minor by comparison to the next RTW truck.
Please, any advice, thoughts, experiences, horror stories, etc will be appreciated. Or even general recovery stories would be appropriate here.
