Robert Bills
I know aftermarket axles with electric brakes are available to fit just about any trailer and lug pattern, but I am trying to determine whether it is possible/feasible to add electric brakes to a stock Bantam civilian T3-C axle.
For those of you who aren't familiar with the civilian Bantam trailer, it uses an axle with full floating hubs and a 5 on 5 1/2 lug pattern for early Jeep wheels, but no brakes. The military trailers of the era used essentially the same axle, but fitted with drums for a parking brake (same drums and brake shoes as the early Jeep).
Every modification to my trailer has been done in a manner which allows the trailer to be returned to 100% original (i.e., no cutting or welding to the trailer itself, with all removed original parts cleaned, preserved and stored away for potential future re-use). I would prefer to use my original Bantam civilian axle (don't really have room to store it if replaced), or an axle from a WWII T-3, MBT, or M100 so that I can retain the full floating hubs and stock look.
I am familiar with a T3 (or perhaps it's an MBT) in Southern California with hydraulic brakes controlled by the tow rig (1960's era brake controller with piston in the connector to the trailer that actuates a master cylinder mounted on the trailer). However, I want to use modern technology and would prefer true electric brakes rather than electric/hydraulic (although at this stage I will consider any option).
Has anyone done this or seen a Bantam axle modified with electric brakes? Electric/hydraulic with a "modern" brake controller? Either of these set ups with a parking brake feature?
Any and all information, tips or leads will be appreciated.
Thanks.
Thanks.
