vacuum disengages front axle disconnect. So if you don't have vacuum you will have permanent 4WD. Smartly done by Mitsubishi since if you loose a tube in a bush you will have your 4WD system functioning. With center diff won't matter much on pavement.
So theoretically if I have manual front locking hubs, I can disengage this system without any ill effects?
What could be a cause of a sudden disengagement of the drive train when in any 4wd mode when applied a load to. It is not the transfer case, though this has caused the destruction of one transfer case already. 2wd is fine. When it disengages, it produces a horrible grinding noise. If I had an exploded view of the transfer case innards and where it ties into the transmission, I'd be fine to figure it out.
Any help is welcome and let me point out that my montero, even without 4wd is a beast off road. Granted the rear locker helped.
