4x4tripping
A DIY project Power Systems with 12v, Solar vs an Ecoflow Delta2 - which solution is better?
It is not easy to compare, because both solutions have some advenate/disadvantages.
Both variants did come with LiFePO4 and will have after 3000 Cycle times arround 80% capacity, the ecoflow and the DIY - in my comparison.
So even with a daily use, it will have over 80% of the capacity after 8.3 Years. Guess that is not an point to discuss anymore.
The space required by the DIY project and the weight are the main disadvantages, together with the starting price.
And you can`t just use cheapies for the DIY buildup, when you want to have an serious warranty like the ecoflow did provide (5 years)...
Ecoflow Delta2 vs DIY Battery
A DIY project Power Systems with 12v, Solar vs an Ecoflow Delta2 - which solution is better? Battery solutions in comparison!
vanlife.4x4tripping.com
trippin
