FYI: Typical Minnesota rusty bucket van...
Sorry I'm sure this have been ask a million times already (but I may have a good idea too)
What is the best product, method to stop the rust from eating my newer van (is already half eaten in some places)
I love POR 15 but the amount I will need will cost me more than the van itself, I don't like the "Oils" I want something "Solid" after I'm done removing as much rust as possible (Minnesota van you know)..
Second on the sprinter forum I have seeing some really sad pictures of vans that use polyurethane foam and the panels "Canned" like crazy, i'm sure the steel on the E350 is much thicker..
My funky idea, the main critic about the polyurethane is that is Hydrophilic, ergo will end up rusting the toe kick panels (the very bottom of the panels)
So my silly idea is to install "Whipping tubes" (The tubes the use on the outside of foundations, that is full of holes but has a mesh to prevent the dirt from coming inside (on the top and sides will be covered by the expanded foam), the concept is very basic, the Bottom of the panel will be fill by the Tube so no space for the wet dirt/dust to accumulate, then with some holes drilled on the metal the water will drop out the vehicle..
kick my butt if is stupid, but I don't think is a half bad cook concept..
This is my procedure so far, but I welcome all the sound advice I can get..
I already have the small poliurahen kit ready to go..
Please tell me if I'm missing a step or i have a obvious misconception
1) take all the plastic cover panels.
2) dust off as much as possible
3) gatter the collection of candy rappers mix it with dirt
4) power wire brush the inside of the walls
5) apply the "Anti rust" chemical and paint on top for added protection for the metal.
6) install the "Drainage tubes" (or whatever is the best solution to avoid stagnant wetness and moisture accumulation.
7) save "Channels" for stereo components and whatever other wires, tubes or fixtures will bring long term benefits.
8) Spray the Polyurethane foam as thick as the inner wall permits.
9) trip the over spray (over grow)
10) Install plastic panels back and enjoy winters with out the engine running.
I'm sure I'm missing something, help please.
