mtnjp
Got my DV8 rear bumper installed , and so far I'm pretty pleased with it. I happened upon this company while searching bumpers online. They seem to be a newer company out of Riverside Ca. I got their RS2 series which is a bumper tire carrier combo. The thing I liked about it was the one handed opening feature. The tire carrier is connected to the rear door via 2 heim joints. It seems to operate pretty smooth and has been rattle free for 3 pretty long trips around the Salton Sea and Mecca area. The carrier is engineered supposedly for up to a 40" tire, it seems pretty beefy with 2 tapered bearings. I don't see going bigger than a 35" tire and some rotopax cans off the rear so I think it will hold up. The textured powder coating seems as good as most I've seen. It also has a integrated class 3 receiver which is reinforced front and back. It is made of 3/16th steel which seems pretty standard, could definitely hold up to a rear collision which is likely up here in the mountains. The install is straight forward with good directions. All the holes lined up perfect which made the install a breeze. The only pitfall I had was missing a spacer between the rear crossmember and the bumper. I hate coming up with extra parts when the install is done:Wow1:, but my fault. One beer later it was fixed :ylsmokeefinitely worth a look if your in the market.
