charlieaarons
I just thought of the best reason why DRWs are a problem in a vehicle that goes offroad a fair amount:
If the pressure in the rears is significantly lowered the bulge in the tires will rub, potentially causing rapid heating. Does anyone have a duallie pickup and does the owner's manual proscribe pressure lowering because of this reason?
Typically there is only 5-10mm of clearance between properly inflated dual radial tires. Large radials can squash out up to 35mm at decreased pressures which are "OK" with the mfg in a low speed offroad SRW application. According to my Michelin data sheets.
Does anyone actually have personal experience running dual rear radials at 35-40% highway pressure?
Charlie
Charlie
