OK Gang,
I am planning on installing a couple of dual battery systems in my D90 and another simpler system in the AT Horizon.
My Questions (then i will get to the planned setup in both)
1. Dual Charger systems, National Luna or something like a T-Max - i am asking due to the disparity in cost of the 2 systems for what seems to be a fairly straight forward device. Pros/Cons would be appreciated. I am leaning towards the National Luna system but this is really from the fact that they seem to be the top grade standard here rather than knowledge and i would like to be more informed.
2. Do have have enough Capacity (aH) for the below scenarios
Proposed setup:
D-90: Dual Battery Controller with 2 - G34 Optima yellow top batteries (55AH).
Usage is normal Truck loads, Winching (Both on the "Truck battery"), and occasionally ARB 50qt fridge on the house battery. I may move to a dedicated truck fridge with something like the engle 27qt full time. The real reason for the Dual is going to be redundancy while traveling (for instance i have lost the alternator on the trail before)
AT Horizon: 2 - G34 AGM batteries in parallel (Sears, since i have one Platinum already, I will buy a companion G34 AGM. This takes charge from the truck while driving, and i do have a 65w solar panel with Blue Sky controller as well. But needs to power the fridge for 3-4 days with only the solar as primary charger. The rest of the load will be from charging cell phones, and running the LED strip lights.
Thanks in advance
Proposed setup:
Thanks in advance
