Pest
I'm trying to estimate our power usage per day in order to size the right battery and solar setup.
My only problem is with the fridge. It's a Dometic RM 2354 LB 3-way fridge. There are labels on it for current consumption while operating on AC and on DC (meaning no gas, which is huge at 15ish amps), which is fine, but the problem is that it has a controller. I can't find much information on how much power the controller draws. The fridge requires a DC connection at all times to run, even when on AC or Gas, this is strictly to run the controller. I can't find much information on how much power it draws. The most I could find was that it has a 3A fuse for the controller. If it draws 3A, then the fridge is pulling 36W just to run off gas...this means 864W per day! That seems like it's way too much, but I'm not sure.
Any ideas?
Thanks.
Any ideas?
Thanks.
