Overlandtowater’s solid axle suburban
Overlandtowater
Alot done today, replaced a loose idler arm, this one was twice ss thick and way more beefy same part# as before. Changed oil and filter, cardboard aided design the front diff skid, got the bumper supporta welded on ( only problem I will have to cut them off to remove the bumper), welded on one recovery point.20201010_170742.jpg20201010_170748.jpg20201010_223349.jpg20201010_223355.jpg20201010_223405.jpg
Overlandtowater
Yes the welds are rough, I'm using my 110 flux core welder on 5/8" thick stuff, first weld slow by turnind down the wire speed. Preheating helps a ton, purposely leave a gap to fill further slowing down the speed. I was able to heat the 5/8 while welding to the point the opposite side was cherry. I think I got good penetration I was able to stick a 3/4" solid bar in the whole and bebd the bar without the mount moving, that said I'm going to fish plate the flush side for more weld contact.
Overlandtowater
Fish plated the d-ring mounts and got mr rear recovery point done. Let that sucker cool slowly by dousing in aand and letting it sit.20201011_113109.jpg20201011_131336.jpg20201011_132125.jpg20201011_153155.jpg20201011_153223.jpg20201011_153619.jpg
Overlandtowater
So being down from my eye I lost about a weeks worth of work and again the sliders didn't get done. I would really like to replace the rockers before welding on the sliders but that is going to require paint and if I'm going to paint the rockers I need to paint the whole lower portion of the doors and the bumpers and sliders.
ITTOG
Delays suck.
So was that weld slag in the eye? I hope it is getting back to 20/20 for you.
Overlandtowater
The #rendezvousintheozarks was great over 650 rigs showed up. I ran a bunch of trails with #smsoverland it was a great long weekend. I ran the suburban through stuff I probably shouldn't have been on. The Ozarks get terribly muddy but we are in a dry spell well we was the night before I left it rained all night and I backed out of my last trail day being alone. The first day was a road day 6.6 hours on the road but there are views on the highway too. We ran the back way into byrds adventure center from ozark Arkansas 20201015_144654.jpg20201015_154104.jpg20201015_154801.jpg20201015_154837.jpg20201015_173551.jpg
Rinzlerz
