Overlandtowater’s solid axle suburban
Overlandtowater
Started cutting the bumper tube in the shape i want, I just made a pie cut leaving the bottom of the tube to weld back together instead of cutting the whole section of and needing to weld a strap along the bottom. I think it'll work out great.20200821_210103.jpg20200821_210105.jpg20200821_210112.jpg20200821_210826.jpg20200822_113610.jpg20200822_113619.jpg
Overlandtowater
Im a grinder not a welder. This little harbor freight welder is doing an ok job especially since it is running off a 50ft extension cord. I wa finally able to get the maximum use from a cut off wheel with out it getting pinched and exploding.20200822_125630.jpg20200822_125637.jpg20200822_130435.jpg20200822_130538.jpg20200822_130541.jpg20200822_124214.jpg
Overlandtowater
Almost done with the mounts...i need to cut one more strap from the 4x8 sheet and i will be able to finish....by the way that 110 flux core welder started welding like a champ when I swapped to the .35 wire20200822_185206.jpg20200822_185211.jpg20200822_210702.jpg20200822_210714.jpg20200822_210719.jpg
Overlandtowater
Its in no way perfect bur when you're Dad wants to help you don't complain... got the big holes drilled, hitch welded in notched out the bumper for the sliders.20200824_235644.jpg20200824_235658.jpg20200824_235750.jpg20200824_235823.jpg20200824_235901.jpg
Overlandtowater
I'm pretty sure I over engineered the bumper....I put the swing-out out and sat on the end of it to see if the bumper would bend....the only thing I saw bending was the frame of the truck....It would bend so far down I could stick my pinky between the bushing and the mount...if I wanted too...
Heavyhoe02
my rear bumper and swing gate have flex in the same way but prolly weights 2x as much as yours, nothing to worry about
Randy Towles
