6Speeder
British Columbia, Canada
Picked up this truck a few months back and I've been meaning to make a build thread to track my progress and get suggestions. It's a 1990 Leyland DAF T244 military truck. It was originally used as a training vehicle at CFB Suffield outside Medicine Hat Alberta by the British military. It spent a few years on the Lower Mainland where it was painted, registered and insured by the previous owner.
Truck: 1990 Leyland DAF T244
Engine: Cummins 12 Valve Turbo Diesel
Transmission: Spicer 5 speed manual
Drive train: Full time 4wd will center locking diff and hi/low range.
Brakes: Wedge style air brakes
Curb (tare) weight: ~13,600lbs (I believe the truck is now closer to 12,000lbs with the bedsides remove and the load deck stripped down)
Max gross weight: 23,800lbs
Deck size: 14x8'
Fuel consumption: 16.8mpg @ 30mph, 11mpg @ 50mph
Max speed: 55mph
I chose this particular truck for a couple reason. First, the Cummins engine is entirely mechanical, reliable, easy to service and ubiquitous globally. The cab tilts forward to allow complete access to the engine for service. Second, the general size of the truck and load deck met the requirements for my project and lastly these trucks are affordable at roughly half the cost of a comparable Unimog or Fuso.
The plan is to build a ~110' living space on the back of the truck. The planned modifications will be as follows.
Truck Interior:
Cab interior full stripped back, sounded insulated with custom headliner, walls & door cards, custom overhead console with radio, auxiliary switches, CB & VHF/UHF radio, heated suspension seats.
Engine & Drivetrain:
CAV to VE injection pump swap, larger injectors, stiffer valve springs, exhaust brake, KDP fix, ARP head studs, diesel engine pre-heater and a larger fuel tank. Current power output is 145hp and I'm aiming for 225-250hp just to maintain speed on hills. Potentially investigating install an Eaton 6 speed gearbox to give the truck a sixth gear overdrive which will improve fuel consumption and increase cruising speed. Modifications and upgrades to the engine will follow the construction and completion of the living quarters.
Living Space:
17x8' steel framed box constructed with 2x2x0.100" square tube clad with Dibond aluminum composite panels adhered with VHB tape. The completed structure will sit atop a stripped back version of the existing load deck. The current rigid deck mounts will be modified to accommodate springs allowing for increased articulation without deck deflection. Interior walls will be furred out a further 1" with timber to reduce thermal bridging and allow the use of 3" IKO Enerfoil insulation which will give an anticipated R valve of nearly 20. Windows and door will be scratch and dent take-offs from a local RV dealer. Heating will be provided by a diesel heater and Cubic Mini wood stove. I have chosen to go with a steel framed construction method as I anticipate installing a rear motorcycle carrier capable of holding a 600lb motorcycle.
At this point I'm still in the early stages. I've stripped back the load deck and interior of the truck and am performing some routine service to the engine. The next step will be construction of the steel frame for the living quarters. I'll try and post somewhat regular updates as the project moves along.
If anyone has any questions or suggestions, let me know.
