chadzeilenga
Hi All,
I'm looking for some additional input on an issue I've been struggling to solve. The issue is rust in my coolant. I've noticed since I first purchased back in March 2018 and below are the steps I've taken to solve it.
So far I have done the following since I purchased the vehicle back in March listed in order:
- 2 rounds of Blue Devil Cleaner flush. Drove for a few days with this in. Still had rust in coolant.
- 3 rounds of fill and drain from lower radiator hose with water on warm engine and thermostat open (dumb idea)
- Backflush of coolant system with garden hose through Tee installed by previous owner in the heater core hose. Started engine and ran until water out of radiator was clear.
- Added 16oz/1gal mix of Sulfamic acid to remove mineral deposits. Ran without thermostat for ~3hrs on highway. Allowed to cool and drained from lower radiator hose
- Added 16oz/1gal mix of Oxalic acid to remove rust deposits. Ran without thermostat for ~3hrs on highway. Allowed to cool and drained from lower radiator hose. Did this twice
- Neutralization with 16oz/1gal mix of washing soda and run for 15min to mix and then drained when cool.
- Removed aftermarket radiator and did backflush on cold engine through the tee in heater core line. Let water run for ~15-30min. Plugged lower radiator hose so that coolant came out of bypass hose connections.
- Poured (2) gallons of distilled water into the tee on heater core hose to displace and minimize the existing tap water from block.
- Installed recently rodded OEM radiator and all new radiator hoses, heater core hoses and coolant bypass hose.
- Added 1 gallon of straight Green antifreeze. Allowed to mix with existing straight water in the block and then topped off with 50/50 mix until all air was bled out.
I ran with this configuration for a few days and I'm getting a significant amount of rust sludge floating in the top of my coolant when I remove cap and also it is stuck to the bottom of the cap. Below is what I have after 2 days of driving around town.
Is it possible that the coolant loosened up rust that was stuck in the block? I would think that after all of the efforts listed above this would have all been clear or I would have seen just a little bit. Maybe the new radiator is allowing higher flow rate in the engine?
This is a chunk of the rust that I pulled out this morning and let dry. It just turns to powder, so there doesn't appear to be any oil
