Anyone have dealings with this tire?
I have heard that Cooper makes these?
I'm wondering which company advertises the alternative to this..frequently proclaim use of a "cut and chip resistant" compound
Good point, but the compound Cooper uses does seem to hold up better to a LOT of gravel road use than I've seen with other brands of all terrain tires, which tend to look shredded after a while on the same roads. So it is worth something...I'm wondering which company advertises the alternative to this..![]()
At street psi ( I only ran 28) they where ok but once down to 15 they worked fantastic .Thanks— great picture! How about packed snow or slush on the road?
I have a friend that has the EXP's.FWIW, I found that I didn't rotate the FCII's often enough, and this resulted in some chopping of the large lugs, primarily on the front, and the chopping significantly increased noise. Once they get chopped, it's very difficult to get them to flatten out, so keep a close eye, and rotate at the first sign of unusual wear, or every 5000miles if you just want to be safe.
