grogie
Like to Camp
So just after returning from a two week, 3500 mile camping trip out west, and other then attending the upcoming Overland Expo East this coming October, this is wrapping up the third summer with my Tepui Ayer RTT that I have mounted on my trailer.
I wanted to get some advice on care and maintenance, including some issues that I've had.
Overall I love this RTT for its bang for the buck! I could see having a larger RTT, however my trailer is not large, plus the RTT is mounted directly on an opening lid, and being towed by a Jeep TJ, weight is always an issue. I have to also say that I've never slept so well camping then now with this RTT! I have improved the padding with some thin air mattresses, but again an RTT has been an awesome improvement to tent camping.
With that being said...
1) The straps over the cover have always seemed a little loose and the velcro sort of holds the straps in place, but in my opinion they do little with actually holding down the cover like actual ratchet straps would do as the velcro just gives and the straps where they bend are wearing thin. Well along this last trip, I noticed that the front strap was a little loose. On a stop I thought I tightened it back up, but on the next stop I found that the strap had completely come loose and must have gotten under a tire and was ripped off. (Ouch!)
So should I bother replacing it? Again, I don't think that the original straps with just velcro have really done much to hold down the cover? I'll note that I do keep a few things inside the RTT so the cover as is fits well over the RTT when closed up.
2) Last summer I had an issue that I wasn't carefully enough and I let the zipper catch the bottom skirt of the tent as I zipped up the cover. It was bad enough that I had to cut the skirt to free the zipper. My one complaint about this RTT is that the skirt, along with stray treads, wants to easily catch in the zipper and I have to run a finger between the zipper and the skirt to keep the two from catching.
Well along this last trip, I had an issue that the zipper separated further ahead while I was unzipping the cover, which took some help to resolve, and as well when I was unzipping the cover this morning to clean out the tent, I found that the zipper had separated on the back corner. Could my zipper issues be a result of the cover straps being loose (or now that the front strap is not even on)? Should I replace the base zipper of the tent, and as well the cover to get new zippers? How long should I expect the zippers to last from use? With the zippers separating I did find dust all along the base of the tent.
3) Also this morning I took a sponge and lightly wiped off the tent, and the lightly sprayed the sides off, partly to get the dust off the tent from the zipper separating. Should I go ahead and treat the tent fabric? I have not had any issues with rain or moisture getting through the tent fabric even after some heavy rains that I've experienced. The RTT has remained dry inside.
And yes, that is a buffalo in the background!
