BPred's 2006 DC SR5 Tundra Build
bpred
About a year ago my sister-in-law bought a first gen Tundra Access Cab. I borrowed it once in fell in love. I knew I would need to get kids in and out though so I decided to go with the Double Cab and so I started looking. Car prices in San Diego seem to be higher than other places and I was having a hard time finding anything reasonable in the area so after a month or so of looking expanded my search. Ended up finding one in Portland, OR that was perfect. After a couple phone calls I bought a one way ticket and flew up and drove home in a new truck.
The truck was in pretty good shape accept a couple scrapes on the driver side, but that's what trucks are for so I didn't much mind.
I was home less than 24 hours and before the work started. Headlights needed cleaning. Bought a new head unit with bluetooth, backup camera, and all the toys.
I know this site has helped me and given me a lot of ideas so I figured I'd start my own build thread in case it helps anyone else. Here's to adventure!
bpred
I made it almost a month before I got a misfire. Still, it's better than the Miata which blew the radiator on the way home. I was going to replace the coils with better aftermarket ones but couldn't find anything I loved that was available (I put MSD coil packs in my Mustang and loved them). I ended up getting all eight off Amazon for the same price a single OEM was going to cost from AutoZone. I've been told since I should have gone with the OEM one's because they're so good but I still have the working 7 and if these ones ever go I may go back (but these in back in May 2018 and they're still going strong 8 months later so they can't be all that bad.
bpred
I didn't like the green glow of the instrument cluster so I pulled it to change out the bulbs to white. At that point I found out that, at least on my model, the lights were already LEDs from the factory. The green tint was a layer on the back of the gauge face. I figured I'd buy a new gauge face and update the look (I bought one for the Miata from RevLimiter which is amazing and thought I could do the same). Apparently these are a couple hundred bucks which seemed excessive. Current plan is to try to sand off the green bit per someone around here's recommendation (link when I find it).
I replaced the rest of the bulbs in the car with LEDs while I was at it. Most of them I don't like because they're way too blue. They're in the 6000K range and I think the plastic pieces that cover them make them even more blue since the original incandescents where so yellow. I've had a hard time finding any LEDs that are actually 5000K. The one LED modification I made which I'm happy with was the one I flip flopped on so many times because it was so much more expensive than I'm used to paying for LEDs. I bought a footwell kit from VLEDS . It was worth every penny. The parts are high quality and easy to use. Normally I get frustrated with these installs because the adhesive ends up giving up and the connections come loose. These don't; they're brilliant.
Too blue:
Worth it:
bpred
I had been driving the truck to work most days but once I week I take my wife's car and gas it up. On one of these mornings, I got a text from my wife that the truck had been hit. And this, ladies and gentlemen, is why we can't have nice things. Ends up she was 18 and apparently her dad expected this situation may happen because they had really good insurance. I took it in to the shop, they evaluated the damage, and 30 minutes later I had a check. If I had known how easy it was to get money by having your things ruined I would have done it years ago!
I looked at the pricing for how they came to the total and realized the whole thing was a racket. For example: a got $120 for a single taillight. I knew for a fact I could get two for $100. So I did.
And so it went as I looked down the list. Everything that was damaged was way over valued by insurance. This means one thing: upgrades. And so I started looking at bumpers. After doing some research I decided to go with Move Bumpers. I liked their customization options and they were way more affordable than most others. The only catch is you have to weld it yourself. Fortunately I have a few friends who are professional welders.
I also included some Nilight reverse lights which I need to finish wiring up.
Kpack
Pull your gauge cluster, take off the panel, and then use wet sanding paper on the back of it to remove the green film over the parts you want white. I used black spray paint to paint out a couple things I didn't want showing through at night (I don't need to see KPH). While you are in there, take off the green plastic film from the odometer. It's just a thin piece of plastic. That will leave the odometer white like the rest of the cluster. Page 1 and 2 of my build thread have a couple of pics showing it.
For the LEDs I went with these (https://www.amazon.com/gp/product/B076V1TQ96/ref=ppx_yo_dt_b_detailpage_o08_s01?ie=UTF8&psc=1) and they have a nice warm white to them. Not pure white, more yellow, but very bright. No blue whatsoever. I used them on all map lights, door lights, etc. I used the 6000K white/blue LEDs for behind the A/C cluster to get those to show more white like the speedometer.
#6
Just an fyi, I imagine the insurance company was giving you the replacement cost for an OEM Toyota tailight, as they should. If you are getting two tail lights for $100, they are aftermarket and definitely not oem.
Good looking truck.
#7
I know they're definitely not OEM but they're DOT approved. But I also didn't want OEM. If I could find better looking aftermarket ones I would have put those on there even before that. :p Even if I were to go OEM I would have just picked one up from a yard for $20 and called it a day, haha.
