Best Gear Oil We've Used - Now @ Nitro-Gear.com!
nitro-gear
Supporting Sponsor - Differential & Axle Parts
80W-140
Nitro Synthetic Plus Gear Oil - Click HERE To View Product
Friction is a killer to your moving parts. Our Synthetic Plus by Schaeffer's Oil is engineered to reduce friction with superior lubrication. Studies show it reduces your operating temperatures by up to 35%* and reducing wear as much as 25%*. Less friction means better fuel economy. There's nothing like it that will add miles to the adventure.
*Individual results may vary.
Tech note:
Each differential requires 3 quarts of oil.
Ford Superduty rear differentials require a minimum of 4 quarts.
Features & Benefits:
A vast reduction in the formation of deposits.
Better heat transfer.
Excellent protection to the gears and bearings even under the most extreme thermally, stressed operating conditions.
Less wear to gears, bearings and seals.
Increased oil seal life.
Lower operating temperatures
Less energy consumption
Longer lubricant and equipment life
Reduced equipment downtime and maintenance costs
Nitro Gear & Axle strives to provide the highest quality differential components available. We take the steps necessary to ensure our parts are dependable. Our product range is continually growing to meet the needs of consumers for new ratios and applications. At Nitro we know differentials, and know what it takes to provide you with high-quality components.
Randy Towles
