So dusting this thread off a little. I decided to put a new axle under my trailer and ordered it with the 5 on 5 lug pattern. I wanted to use the JK rubicon rims(thanks TenatiousTJ) and run 255/75R17's. Found a good deal on some used 265/70/17's so they are close. This turned out to be kind of a hassle but it all worked out in the end. I ordered a Dexter 3500lb axle from the guys at VMI. Figured that the JK rims wouldn't fit over the trailer hubs so I ordered a set of spacers and had the axle shortened to make up the difference. Well the spacers showed up and wouldn't you know they wont even fit over the axle hub. So instead of paying to send them back and get ones that would, I found a local machine shop open them up to fit for 20 bucks. Get those back today and bolted on. So finally get to mount the rims and tires on and bam, even the ez lube dust cap is to big to fit through the JK rims center hole.....so for now, until I get the new dust caps, the little jeep caps will have to work. Just no water crossings for now. I'll get some pics up tomorrow. Got to finish up a few odds and ends and it'll be back on the road. For now I left it spring under and the 265's look huge under a stock 416, kind of low and wide now...but since my new jeep is stock height for now, i'll live with it.
