Yellowstone2Yukon
Newly settled in the Pacific Northwest after years of rambling from Utah to Alaska. In all those years, I've always dreamed of having the perfect expedition camping vehicle, and what better time than now to build one?
Enter my 2005 Chevy Astro AWD.
It's a former oxygen tank transporter. Currently has a ladder rack on the roof and a slide out vault drawer about 11" wide in the back, mostly stripped otherwise.
The plan is to have it be a base camp vehicle that has the capability to sleep two adults. As such, I'd like to be able to do some cooking and washing inside, but not planning on making it into a full-scale RV type setup. Also going to be my daily driver, so fuel economy and highway drivability are important. Here's a very rough outline of the areas for design and current priorities.
Interior:
I like the existing vault cabinet.
The issue with it is that I don't have much use for the little bench on top of it and don't want to put the bed over it since it's on the shorter side of the vehicle. I've considered putting a twin-XL bed on the other side and putting a ceiling-length cabinet over the vault cabinet. Kitchen will be the same height as the bed and current vault cabinet centered in the back with a removable cover. That way there will be a space big enough for my feet and a walkway between bed and vault cabinet. Very crude idea of my intended layout is done in MSPaint here.
As for bed, a VW-style deal center-facing couch that converts to bed would be nice. I'll have to get exact dimensions, but twin while folded up and full while down looks like it would fit perfectly. The existing rail in the floor would also be a good place to put it. I'm not really sure where I can source the folding bed or if I'd have to make something up myself.
Before adding much of anything to the interior, I'm going to insulate it, since I've spent a lot of time in very cold places. The rough plan is bubble wrap all around with layers over. Floor covered by carpet anywhere that winds up being exposed, durafoam ceiling, and fiberglass/vapor barrier walls. Not sure what I'm going to finish the exposed parts of the interior with, over the vapor barrier. Wood seems a bit overkill, I want something easy to clean, durable, and light.
Not sure what I'm going to do about window coverings. I'd like some kind of blackout curtain that provides insulation but can be moved out of the way between the driver's compartment and over the sliding door and back door windows.
Electric:
I plan on adding a deep cycle auxiliary battery soon. The most logical place I can think of is directly in front of the driver's side wheel well. As for an inverter, a 300+ watt pure sine inverter/charger would be ideal, and I'll definitely leave space in the box for one, but a 150-watt regular inverter in the dash area might be the first step. There's room for a lot of accessories in the dash as is, and I think I'll put my 120v and USB plugs just to the right of the stereo, where the rear climate controls would be if I had rear climate.
Stereo also needs to be replaced and I'm going to put in something that works as a more general entertainment center when parked.
A cell phone signal booster is also pretty much a necessity for a serious expedition vehicle. Somewhat lower priority than stereo and auxiliary battery due to cost and the fact that I don't have a pressing need for it at the moment.
External:
An awning of some sort would be handy to give me space even if there's some weather. Since the kitchen will be in the back, maybe something there as well as/instead of over the sliding door?
I don't want to put too much weight on the roof. It seems like a good place to fit tent, sleeping bags, and other light but bulky equipment, but I don't really want to remove the existing ladder rack. Is there some type of Thule box or something similar that I could fit on the ladder rack? Maybe a half-length basket? The only recreational equipment I can think I'd like to have up there is a sea kayak.
I want to move the spare tire to the back door. Sharkfox had a pretty slick system for doing that. I'll also probably stick my fuel jerrycan on the other door the same way. That will probably wait until I've got new tires and wheels figured out.
I want a good brush guard and bumper, preferable with a winch and "moose lights". Looks like that will have to be custom fabricated or at least customized. Probably needs to wait for the lift to be done.
Suspension, brakes, and tires:
I'm planning on lifting it with one of the Overland kits. The 4" version seems like a better idea overall. This will wait until I need new tires, which means probably at least a year. No specific tire plans, I want something very durable that's good on the highway and efficient. I've got discs all around and I'm pretty happy with braking.
Driveline:
No current plans.
Suggestions and questions are very welcome. I'll be updating this OP in dribs and drabs as I get inspired and document the work as it goes. Parentheses will be replaced with photos very soon, other photos available by request.
I was going to link to all the Astro/Safari threads that have inspired me, but I'm not allowed to post links yet.
Interior:
Electric:
External:
Driveline:
No current plans.
