An idea for a fishing pole rack / surf fishing pole holder
rayra
Driving today I noticed this rack in the service bed of a work truck.
Gardeners around here usually use PVC pipe clamped to a lumber frame. This appears to be an electrical conduit mounting / suspension rack, with its purpose-made clamps. Same sort of mount would work well for mounting an overhead rack on a trailer or bumper, or a pole holder on a bumper. And when the Mad Max Apocalypse is upon us...
Unistrut with pieces of conduit using unistrut conduit clamps - available at any big box home improvement store. Conduit sizes up to 4"
Wilbah
But how will I mount my razor sharp boomerang?
D
Deleted member 9101
Guest
I mounted mine under my tonneau cover.508793
jacobconroy
Hillbilly of Leisure
Front Runner makes one for snowboards/fishing poles. It's flat on the back and will bolt and/or screw to anything. I have had one sitting around for a couple of years and am finally going to use it for storing an extendable ladder. It locks too.
Overlandtowater
you can stretch a couple of hammock tree straps across the suburban at the roof in the back then you have a slot to hang rods every three inches. you can stretch them tight by bolting them where the coat hangers are. I still have to find a couple of cheap or broken straps to test it out.
Halligan
Google "truck fishing rod holder" and there's many images and ideas to choose from. Some are commercially made units while others are home made. As with anything else there is more than one way to get the job done.
norcalmaier
