Alternative to solarblvd.com?
frans
This business had a complete system, two 100w folding suitcase style solar set up for a couple hundred bucks. Now they seem to be closed
Can anyone recommend an alternate company I can buy my solar panels from for about the same price?
Thanks
Frans
Bayou Boy
Just FYI. If you search the exact same specs as Renogy stuff on Amazon you will find other brands of the exact same things for significantly cheaper. Renogy is just a relabeler of stuff from some factory.
For example:
https://www.amazon.com/HQST-Monocrystalline-Solar-Compact-Design/dp/B07L7ZGGVT/ref=sr_1_1_sspa?crid=35S7HV1ECA6SC&keywords=hqst+100+watt+12+volt+monocrystalline+solar+panel&qid=1561721094&s=gateway&sprefix=hqst%2Caps%2C159&sr=8-1-spons&psc=1
https://www.renogy.com/renogy-100-watt-12-volt-monocrystalline-solar-panel-compact-design/
Here is HQST's suitcase.
  • Like
Reactions: plh
loonwheeler
I contacted HQST and they replied their 100 W fixed panel was a similar design (specs etc) as the Renogy panel but not from the same factory. Hence the difference in cost.
WonaWarrior
