SOLD 96 Ford E350 4x4 ambulance
SOLD
1996 Ford E350 4x4 Wheeled Coach ambulance, 139k/mi, 7.3 liter PowerStroke turbo diesel, auto, runs and drives great. 4x4 conversion was done by Salem & Kroger using F350 4x4 parts.
Ambulance body dimensions:
interior height is 68”
139” in length x 94” wide
Some of the new parts and/or work done during my ownership of the rig:
New turbo
vacuum pump
fuel pump
serpentine belt (a new spare is also included)
injection pressure sensor
cam position sensor
transmission flushed and Mag-Hytec high capacity pan added
I upgraded the stereo to a Bluetooth compatible Kenwood head unit and Pioneer speakers in the cab.
I added Dynamat sound deadening mat on the cab floor and the aluminum floor sections of the ambulance body (it still sounds like an older diesel truck just not quite as loud). The rear floor is carpeted. Butcher block counter top. The bed consists of a double memory foam mattress that was cut in half and upholstered to form a bed or folded up to form a sofa. I re-insulated the passenger side and rear wall and part of the box with two layers of 3M Thinsulate thermal/acoustic insulation, the rest of the orginal insulation in the box is still intact.
Tons of lockable storage compartments inside and out.
All of the sirens and emergency lights have been removed or disconnected, the interior and exterior flood lights are still operational.
What needs attention/the bad:
There is a leak in the AC system, that will need to be addressed to get the AC working again.
Clean and clear title in hand.
Located in Ridgway, CO
Asking $18500
Send a message with any questions or for more information
WonaWarrior
