92 dodge cummins full size expo truck (rare 1st Gen EXcab)
pratty85
(SOLD!!!!!) 1992 Dodge Power Ram W250 5.9L Cummins Turbo Diesel, Extended Cab,NP205 (Gear) transfer case, A518 Dodge auto trans with overdrive, Dana 60 Front, Dana 70 Rear, 3.55 gear ratio.
This is my do it all Dodge Cummins. I started on this project about a year and a half ago. I have documented everything I have done to this truck. Kept all receipts and maintence logs. I built the vehicle to be a sort of Bug Out vehicle/ Expeditionary Vehicle. It has been a great truck and easy to maintain. I don't offroad it, except when friends need to be pulled out and it handles rough terrain no problem. I hate to see her go, but I have another project in mind, and would like to send her to a good home.
240k miles (just broke in) all mechanical cummins VE injection pump, can run off of JP8, JP5, Jet-A, Jet-B, Biofuel, Kerosene, and regular diesel variations. Just make sure you have the right lube oil mixture.
6" Skyjacker Lift
Lengthened front Drive shaft and replaced all U joints
Offroad Design Crossover Steering kit
Borgusen Steering box and steering shaft
5 Brand new Wrangler Duratracs with Procomp Black 8 hole Rims
Front and rear Ranch Hand Bumpers
4 KC 69 series Long Range Spot Lights
Extra thick Rhino Lining
5th wheel pop up ball
80gal transfer tank/tool box with manual pump
4" Farmboy Diesel Exhaust
100hp Red Oak Injectors with slight pump tune.
New fan clutch
Yellow top optima battery
Oil changed every 3k miles 15w-40 Valvoline
Valve lash and gaps checked every 25k miles
New Amsoil differential fluid (good for 100k miles)
New rear outer axle seals
New Transmission Mounts, Lines and Fluid
Potentometer
New Brake Booster
Floor pans have no corrosion, installed new carpet
Had original Captains chairs re-upolstered to factory spec and color
New head liner
Has a Galaxy DX959 CB radio with Wilson 5000 antenna
Call or email for more information. (706)978-0015
Located at Ft Bragg, NC
15,450 OBO
[/IMG]
[/IMG]
FranklinDufresne
