What kind of 3d printer? SLA or FDM? that will greatly limit your field usage of the parts unless you are just making a mold for casting the part in metal.
I've worked alot with 3d printers over the past few years so i know quite a bit, nerd time:
SLA printer technology uses resins and UV lasers to cure the resin, these prints have amazing detail and can look damn close to injection molded parts after some finish work but the resin formulations are not really up to par yet for everyday use objects. UV will degrade the part significantly over time and can lead to warping and cracking of your parts, so anything that will be exposed to sun needs to be covered in a UV protective coating. Strength of SLA parts is also an issue compared to ABS, PLA, etc on FDM printers which are much stronger materials.
FDM printer technology uses plastic "wire" on spools that is fed into a hot metal extruder with a tiny hole at the end. The quality of these parts is noticeably less than SLA even on the highest resolution print settings but the trade off is you can print with MUCH stronger materials, namely ABS. The printing process is essentially the same as SLA, cut the part up into tiny slices vertically, then printer on slice at a time, move up a little, print the next layer, etc. and you end up with a finished part.
Imagine you took a ream of paper, and CNC machined a face out of it (in a perfect world where a CNC can cut through a stack of paper without it moving
). When you clear away the scrap paper, your left with a stack of uniquely shaped stack of papers in the shape of a face. You can still see each layer of paper, so the object is a bit grainy but overall you can tell its a face. This is pretty much what you are doing with a 3d printer, you design the 3d model then send it to a "slicer" program on the computer which slices up your model and creates the instructions for the printer on how to print each unique layer, when all combined, create your part!
TLDR:
SLA Printers - Super high quality printer resolution like injection molded parts, but weak materials and not suitable for bearing loads or frequent use.
FDM Printer - Lower quality print resolution (can see print lines, looks like a stack of paper as described above), but MUCH stronger materials available. ABS is pretty much the goto for 99% of projects but there are so many more materials you can print with....
