MummifiedCircuitry
Just a little psa, the shorter 3.0 oil cooler lines will work on the SOHC 3.5 if you don't mind moving your oil cooler over a bit. I was in a pinch, couldn't wait 2 weeks to get the proper replacement oil lines and pay almost $200, also local businesses are closed. Got a set of 3.0 oil cooler lines from the junkyard, they're about 8" too short because the oil filter housing is on the other side on 3.0 and dohc 3.5 I believe. I've driven 80 miles with no issues, good cheap temporary fix until I can get the proper ones. Hopefully this saves someone a headache, I didn't know the oil lines were all different, the more you know.
