Located in 96093, I can ship the brackets and Tie Downs, but not the skids. I regularly travel to Redding and Mt Shasta Ca
My 2nd gen is gone to it’s new home so I have some stuff for sale.
Front and transmission skid plates. I custom built these because I didn’t like most of the aftermarket options. Both are made out of 1/8th steel and have plenty of bracing/reinforcing. They have scratches but no major dents.
The front skid weighs 36 pounds and mounts using 13 (yes 13) factory bolt holes. It also tucks up tighter than most aftermarket skids, and has a hole for the oil drain plug.
The trans skid weighs 23 pounds and mounts using factory bolt holes, but you will need to fabricate a simple bracket to mount it to the crossmember just forward of the trans pan, and install two threaded inserts. It’s pretty self explanatory once you hold it in place.
$250 for both skids, obviously both could stand to be cleaned/prepped/repainted and have speed holes to make your truck faster.
Brackets for a “60” portion rear seat delete. I made the brackets to pick up all the factory seat and seat belt mounting holes and support a nice flat surface where I had my dometic fridge. For the sake of shipping, I’ll keep the platform and sell just the brackets. One picture shows the platform installed to give you an idea
$50 plus shipping for the brackets
I have two factory tie down cleats as well.
$20 plus shipping for them.
email at porko53@hotmail.com is the best way to get in touch with me quickly.
