I've got a 2004 Ford Explorer Sport-Trac that is in need of some new shoes. It has the stock 4.0 V6, 4.11 gearing, and I'll be running stock alloy wheels.
I am pretty well sold on the Duratracs -- we live in Montana and these will be three season tires (we swap to Blizzaks for the winter months) -- but I am open to suggestions as long as they can manage the occasional snowy day. The 245's are just a touch over stock height (255/70-16) and a touch narrower...the 235's are quite a bit taller and a bit narrower than stock. But, either tire should fit with the stock suspension (though the 235's might be a little tight). Initial price point is pretty much identical. My questions are these:
1) Am I going to hate the E load rating on the Sport-Trac if I go with the 235?
2) The 235's are 7 lbs. heavier per tire -- while I know this will adversely affect MPG, is it going to kill my range and impact the truck's handling significantly?
3) Any other concerns I should be aware of?
Thanks for the advice, particularly if you've run either of these tires.
