Rad Coast
Trailer features
-13 inches of clearance (without spare tire) 4 inch Lift spindles available from Timbren
-5x9 foot trailer 13x6.7 feet overall 68 inches tall from ground
-Under 1200 lbs dry
-2x2 NATM certified welded steel frame
-Timbren 2000 lb axel-less suspension with heavy duty spindles and break flanges (upgradable to breaks)
-15 inch radial trailer tires with spare underneath
-2 inch ball
-2 inch rear receiver
-Led tail, marker and license plate lights on 4 pin plug (upgradable to 7 pin)
-Rear levelling jacks and front trailer jack with wheel and flat plate included
-Solid once piece floor with fully diamond plated underneath
-Painted aluminum .040 skin over a full birch construction
-Fully insulated 1.5 inch R-Tech foam board walls, roof and rear galley hatch
-2 30x36 inch doors with 16x26 inch half sliding screen windows
-9x45 inch skylight/stargazer window (new non leaking style)
-2 led porch lights with switches inside
- Tongue box with battery box and switch inside (room for additional batteries)
-Vmax Charge Tank fast charge deep cycle 100 ah AMG battery (the best AMG
battery on the market)
-Progressive Dynamics 4045 power converter 3 stage battery charging wizard that will also charge lithium batteries (new style)
-30 amp shore power with 30 to 15 amp a
Cabin features
-56x78x43 3/4 inside (without mattress)
-Everything is built from Baltic birch finished in low voc water based polycrylic
-6 inch full size memory foam mattress with removable cover
-10 speed Maxxair fan that pushes or pulls air in or out with built in thermostat
-3 large cabinets and 2 drawers
-Electronics cubby with 4 USB cartridges (2 fast charge) battery voltage monitor, 2 110 power plugs with 2 more USB chargers when connected to shore, generator or inverter power (inverter and generator not included)
-4 Recessed warm LED lights on two switches
-2 led dimmable reading lights with USB chargers built in
Galley features
-All built from Baltic birch finished in low voc water based polycrylic
-58x24 main galley counter covered with vintage pattern Formica
-Large double 22 inch stove slide (44 inches overall) covered with vintage pattern
Formica
-3 storage drawers a large 22 inch deep one and two smaller ones
-Large 22x26 inch cooler slide with 12 volt power plug underneath built for a Yeti 45 or dometic cfx 35w it’s also storage for the side tables
-2 18x26 side clip on tables finished in vintage pattern Formica
-1 GFI 110 plug in (must be connected to 110 shore power)
-2 USB chargers a 12 volt plug and battery voltage monitor on a switch
-4 recessed warm LED lights on two switches
-Hatch is on two gas shocks, two locking handles and is fully insulated and waterproof
More options www.raddwellings.com
-Under 1200 lbs dry
-2 inch ball
Cabin features
Galley features
Formica
