2019 Frontier Pro 4x - mounting a ShrockWorks Part #: NFTR3-FBPR-01A front bumper . Tutorial needed .
Total
Hello Everyone : I just purchased a 2019 Frontier Pro 4x , and want to mount a ShrockWorks front bumper Part #: NFTR3-FBPR-01A. Does anyone have a tutorial on mounting the bumper . Or pictures of where the plastic bumper needs to be cut .. Any help will be greatly appreciated .
Total
Bamps
Total
There is a false seam there. That is where you cut. Get a truck door protector to apply afterwards. Heres a couple pics the fist pic shows the door protector on, it makes it cleaner. Hope it helps!
Bamps
Under the stock plastic facia, you’ll find a small bumper that the shockworks will replace so you have to unbolt and remove it.
If you plan to install aftermarket lights to replace your stock bumper driving lights, you’ll need these 514300
Total
If anyone else has pictures of when they installed their Shrock bumper , please post them . A picture is worth a thousand words . Thanks
MNCarl
The Moose
I built a wood ....not sure what to call it... a wood buck and bolted the wood buck to my floor jack and to the bumper.
I can remove and install the bumper by myself...no help needed.
Total
should pick up the bumper tomorrow . Will post picks . This was a installation PDF from Shrockworks .
  • 2005 Frontier - Front Bumper Instructions.pdf
Total
I marked the existing bumper 1/2 " above the seam , marked the spot with some frog tape , then used a 4 1/2 inch grinder with a zip cut ( the autobody place by me recommended that ) . Used a floor jack and a engine hoist ( see pictures ) , It went well . DSC_2636.JPGDSC_3447.JPGDSC_3453.JPGDSC_3456.JPGDSC_3470.JPG
oldtravlr1
Total, MNCarl, Bamps, thanks for the post and details. (y) (y)(y)
From the time you ordered it, how long did it take to arrive? I ordered the ShrockWorks bumper(w/center hoop & headlight guards) last week.
Total
Ordered on May 4 th , Shipped on June 13 th received it on July 18 th . If you are shipping to Canada make sure to have a brokerage company ready for the shipment . Also get a NAFTA certificate from Shrockworks ( then you will not have to pay GST) .
Took forever with the shipping ...
Randy Towles
