2018 f350 diesel $49500 with recovery gear. SOLD !
2018 f350xl diesel supercab 4x4
Truck was built to be used for heavy duty off-road overlanding but never seen any real use and has 14500 mostly freeway miles.
Heavy duty buckstop steel winch bumper with 7/8 recovery shackles and warn 16500 lb winch With forged 1/2 CM hook.
Bumper also has mounts for reciever hitch,high lift jack bar with baseplate and a 14000 lb land anchor recovery spade.
Has 35x12.50 toyo ridge grapplers on heavy duty ford 18 inch steel wheels.suspension has fox 2.0 shocks with upgraded f450 front springs and camper package rear springs with sway bar. Has manual transfer case shift lever on floor and manual locking hubs for reliability.has a locking rear axle and front axle has a differential skid plate.Dual heavy duty batteries with on board chargers and warming blankets And battery isolator switch for 2nd battery, winch also has heavy duty battery isolator switch.engine has a block heater.
Heavy duty Anderson 12v connector on grill provides battery power to winch and enables jump starting the truck or other vehicles or provides 12v power.
Has 110v male plug on grill to power battery chargers ,battery warmers and engine block heater.
Options on truck include dual extra heavy duty alternators,gooseneck and fifth wheel kit,skid plates,110v outlet in dash,trailer brake controller,spray in bedliner with lockable bed tie downs and in bed lights.upfitter switches,remote starter,tailgate step,roof lights and all Weathertech floor mats.truck was professionally undercoated by Ziebart for corrosion protection when it was new but truck never seen any winter driving or salt so frame and underbody Are in almost new condition.
Truck was only serviced by ford dealership and is still under warranty of 3yrs 36000 miles bumper to bumper and 5yrs 60000 miles power train
Klutch7
GLWS. Great looking truck with all the right stuff and none of the fluff. Even has the manual T-case shifter. Just picked up a 2020 and they did away with that option.
Thankyou !
I actually had a hard time trying to buy a Truck like this , first issue was there was nothing old school like this out there that had all the work and heavy duty options Without all the stuff that eventually breaks or has problems like software or electrical gadgets.
so I ordered it from Ford from a blank sheet with everything the way I wanted like manual transfer case to the 11500 lb gvwr 18 inch Heavy duty steel wheels, i was even able to get manual only locking hubs which I never see on trucks anymore.
ripperj
Is the camper for sale? How much are you asking , I may be interested and am also in Ct
Update
all of the heavy duty recovery gear and front cargo basket are going to be included with sale of truck.
The recovery gear mounts to front of truck with high lift ratchet mechanism and pull pal bar behind rear seat.
everthing has padlocks on bumper so it doesn’t “ fall off “ when truck is unattended.
*Military size pull pal 14000
*shovel
*highlift jack extreme
*high lift jack heavy duty baseplate
*two maxx trax
* heavy duty folding hitch cargo basket with custom L-track rails and tie downs.
( can Carry a very large Heavy cooler Or wood box)
Rinzlerz
