2018 Earth Cruiser EXP - $340,000
General:
Well maintained Adventure Vehicle with low miles.
This camper comes loaded with almost every accessory available from Earth Cruiser in 2018.
Maximum lighting, maximum solar, maximum batteries, maximum water, and maximum diesel for extended off grid camping.
Almost twice the mileage and range of the new EC's for a fraction of the price. And it is available now.
Our reason for selling is we have a new Earth Cruiser Terra Nova on order. We won't be able to use the EXP before the TN is delivered.
House:
Very high-quality sailboat style double shell fiberglass walls and roof.
Very high-quality plumbing and electrical by Earth Cruiser with many Euro sourced components.
Expanding roof model (EXP), gives lower clearance and better mileage. Can export vehicle in cargo container.
Five solar panels, 150 watts each, MPPT charger can fully charge batteries even on cloudy days.
Three lithium batteries, 150 AH each.
2000-watt 110v AC inverter and battery charger.
Diesel furnace, diesel water heater and diesel cooktop.
No propane, No shore power, No generator needed.
Artic Breeze DC Air conditioner.
60-gallon water tanks (40/20). Water purification system, you can draw from lakes/streams.
Inside shower plus outside shower.
Large outside powered awning.
DC Isotherm Refrigerator plus, DC Engel 35L frig/freezer on slide-out in lock box.
Hot water recycle valve to save water.
Panasonic inverter variable power microwave
Reading map lights in dinette.
Many USB charging outlets and 110v AC outlets.
Tetford cassette toilet, 8 gallons.
Truck:
2017 Mitsubishi FUSO FG 4x4 Diesel. 32,000 miles. New factory engine at 28k miles.
Custom suspension with ATW springs and RadFlo shocks.
12-14 mpg with a 60-gallon fuel tank gives a 700 mile plus range.
Service available from any Freightliner or MB truck shop in 50 countries.
Automatic 6 speed transmission. Simple straight axles with free wheel front hubs.
FUSO limited slip in the rear axle. Torsen gear locker in the front axle.
CV joint skid plates on front axle.
16.6 T Warn winches both front and rear with synthetic rope.
Black forged aluminum rims, including spare. Toyo MT tires with good tread left.
EC Heavy Duty Rear Bumper w/ integrated 2” hitch
On board air compressor with storage tank. Hose fittings on both sides.
Tilting front bull bar. Limb lifters on cab. Roof rack.
LED light bar relayed to high beams, two LED cannons on power switch, three LED ditch lights on rack.
Truck Cab:
Custom heated and ventilated EC seats, 4 way adjustable.
Cabin sound insulation.
Center console with cup holders and storage compartment with safe
AM, FM, CB, GMRS and Short-Wave radios.
Map lights for each seat.
Mitsubishi lane deviation warning system.
Under cab lighting for night servicing in engine area.
Back-up camera and front bumper camera.
Black out/insulating curtain for pass-through.
Electric key remote. Power windows. Air Conditioning. Best view in an RV.
Tools and Add-ons:
Water hose for potable water and lake/stream draws.
RV standard power cable for shore power.
Digital workshop and suppliers’ manuals.
Air/Hydro bottle jack. 'Nut Buddy' geared lug nut tool.
Four Action Trax traction mats and shovel.
16,000K Pull Pal sand anchor with external mounts.
Also Available:
Motorcycle rack with lifting crane (under 300 lbs)
Bicycle rack.
Contact:
Dave Zuber zuberdog@gmail.com
Edit: minor corrections.
