Up for sale is my 2017 White Feather converted 4x4 with locking hubs and solid front axle. The vehicle currently has 66,000 miles on it and is outfitted by At Overland with a mix of some interior furnishings from Rb Components.
White Feather 4x4 conversion
4.5 inch lift
HD welded subframe
Dana 60 Super mono-beam front axle w/open differential
Fox reservoir front and rear shocks
Red Head steering gear
Front and rear sway bars
2 speed NV271 manual shift on the fly transfer case
Billet wheel adapters
Spicer driveshafts
Alcan rear springs calibrated for front, rear, and side to side weights.
Alluminess Rear bumper with large box bike mount and spare tire carrier
Full length roof rack
Whitefeather aluminum front bumper with grille guard and winch mount
Warn 9,500 lb electric winch w/fiber line haws fair lead
2x2 front receiver
Light force adjustable focus driving lights
White feather air tank rock sliders with onboard 12VDC compressor
Upgrade front axle differential to TruTrak gear drive
Powder coat wheels
40 gallon long range fuel tank
Dash switch hub locks
At overland
Modular RB components 3 Panel bed w/4” memory foam mattress
Lacrosse sofa bed with 3 seat belts. Folds into small bed to sleep two small children. If extra padding is available and cargo area is free then it will sleep two adults.
Galley consists of a 40”w x 28d x 44h aluminum framed cabinet w/glass top.
2 upper galley cabinets
Dometic stainless steel sink.
National Luna dual slide with 60l twin fridge/freezer.
Partner 2 burner cook stove ( set up so that one can cook both inside and outside the van.
Power and Solar
2 160w AT solar Panel with 30a charge controller
1 portable power pack w/automatic split charging isolator.
1 valve regulated AGM group 31 deep cycle battery 105 amp.
1 second group 31 battery
Water resistant Circuit Breaker Panel 8 position.
2000w Pure Sine Wave inverter
3 National Luna 15-LED lights dual power 68 and 188 lumens.
Water tank and system
22 gallon water tank
Insulation for water tank and lines
1 universal Pump and strainer 8 lpm (2.2 gpm) 12v (5Ah) 30psi.
External Hot/Cold shower point mixer valve, shower head and hose.
Truma Water and Air Heating
Truma Combi D6 diesel heater and water heater with high elevation kit. ( water heater holds an additional 3 gallons of water).
Wall and ceiling panel system
RB components interior finish kit
Tweed wall liner panels
Coin flooring
Ceiling fan and vent
1 Fantastic fan
1 Roof vent
Awning
1 Fiamma F45 10’ 1” with 8’ 2” protection
Drawer
1 22w x 30d x 38 h birch aluminum framed drawer
Insulation and dyna mat sound dampening installed in all panels of interior.
Scorpion bed liner sprayed on all rocker panels for extra protection.
Propane
1 Volkswagen Syncro 6.9 gallon propane tank w remote fill kit
1 dual drawer composite drawer system out rear doors 37”w x 44”l x 15” h with center dividers.
Towing
1 towing break controller.
Extras
Rb components headliner shelf
Front window shade
Front door covers
Galley window cover
Rear door stuff bags (need to be installed)
Front seat stuff bags
Front seat pedestal stuff bags
note; Maxx Tracks and Scepter cans not included.
Thanks for looking!
4.5 inch lift
HD welded subframe
Spicer driveshafts
2x2 front receiver
Powder coat wheels
At overland
Power and Solar
Coin flooring
1 Fantastic fan
1 Roof vent
Awning
Drawer
Propane
Towing
Extras
Front window shade
Front door covers
Galley window cover
Thanks for looking!
