2015 COLORADO/CANYON suspension thread
CodyY
looks like Icon has thrown their hat in the ring with 5 different kits.
Total Chaos and King have a shock/arm combo
and BDS has the bro-dozer market covered with a "LIFT"
I really wanna see what GM does with the ZR2 package before I pull the trigger on one of these trucks.
rkj__
And, there is the selection of cheap leveling kits to prop the front up just a bit.
Rough Country
http://www.roughcountry.com/gm-leveling-lift-kit-922.html
Zone Offroad (Body lift available as well)
http://zoneoffroad.com/blog/?p=4429
Ready Lift
http://www.readylift.com/products/c...eling-suspension-strut-extension-66-3080.html
Suspension Maxx
https://www.suspensionmaxx.com/store/product/SMX-10195
Auto Spring
http://autospringcorp.com/index.php?main_page=product_info&products_id=94
I'm sure there are many other products in development as well. I've heard rumours suggesting ProComp is working on a 6" kit, as well as a smaller lift, around 3".
CodyY
I'm definitely digging the Icon/TC style setup. I mainly want to see if they change the A-arm length on the zR2, and if it comes with locking diff's. would make me so happy. I'm not holding out for the integrated winch, but it sure is cool with the controls on the dash like the concept.
FLoffroad1
Very cool stuff.
It's a bit odd though - Icon seems to suggest a maximum tire size of 32x11, despite an up-to-3in front lift.
I would've thought they would've tried to find a way to fit 33s. I think a 2015 Colorado with 255/80R17s could be very cool.
CodyY
According to what I've read, GM has fitted the largest tire size under the ZR2 to package. Without rubbing or cutting that is.
nmatcek
Looks like this new generation colorado already has more aftermarket support than the first gen. I like the icon stuff. I don't see anything too "bro" about the bds kit.
rkj__
This is "bro." 8" lift and huge wheels.
Subframe lift kits often are not a big hit among the expo crowd, because although they give the lift needed to run bigger tires, and help a lot with approach, breakover, and departure angles, the crossmembers still hang fairly low, and usually, neither suspension travel nor performance are increased.
That said, I feel that in some cases they are the best option. Sometimes a 1-2.5" lift is just not enough, and subframe kits help keep the drivetrain angles in check.
Looks like this new Colorado/Canyon is poised to be a much bigger player in the mid-size truck arena than the 1st gen was. I'm excited to see what kind of builds people do with these.
nmatcek
Subframe lift kits often are not a big hit among the expo *ELITIST* crowd, because although they give the lift needed to run bigger tires, and help a lot with approach, breakover, and departure angles, the crossmembers still hang fairly low, and usually, neither suspension travel nor performance are increased.
Fixed it for you
superbuickguy
It's interesting to me that no one is building new fenders and bed sides with raised wheel wells. I think the Canyon/Colorado both suffer from very low arches - thus, rather than screwing with the suspension, fix the issue - fender interference. Best part, factory warranties stay intact. The only reason to go up in altitude is to gain clearance because the lower your CG, the better you are off-road (mud racers being the exception here)
Bushwacker Inc.
Supporting Sponsor
It's good to see some more suspension bits coming out for the truck. However, there is a distinct lack of aftermarket wheels at this point, thanks to the oddball 6x120 bolt pattern.
- Andy
norcalmaier
