2013 RAM 2500 Cummins Manual w/ Norweld Flatbed - SOLD
eXpeditionXterra
2013 RAM 2500 Cummins Turbo Diesel 4x4 6-Speed Manual, Norweld flatbed, - CAMPER SOLD
Located in Southern CA
2013 RAM 2500 leaf sprung (pre 4-link coil 2013.5), Big Horn edition, 6-Speed manual transmission, factory limited slip truck. 100,000 miles. Completely deleted. Every service done with receipts every 3-5k, never spared an expense on any repair or replacement. I will probably forget half of the stuff that this truck has on it, but here it goes:
KBB puts the truck at 35k, we know this is probably more in the current market, but it’s what I am using for a baseline.
Double R Diesel delete kit and tunes, shibby plug kit, EGR delete, MM3 tuner, JAMO 5” turbo back exhaust – 3K plus installation
FASS Titanium plus fuel heater and BD flow-max sump kit plus Fuel rail high pressure plug – 1K
FASS TS D07 100G Fuel Lift Pump 100GPH 98.5-18 Cummins (dieselpowerproducts.com)
Fleece Cheetah VGT turbo – 3K plus installation
Fleece Performance 63mm FMW VGT Cheetah Turbo 13-18 Cummins (dieselpowerproducts.com)
Southbend Dual Disk Organic Street Clutch with upgraded hydraulics – 1.8K plus install
South Bend Street Dual Disc 05.5-18 Cummins G56 6 Speed (dieselpowerproducts.com)
BD Diesel Throttle Sensitivity Booster Kit, BD Diesel High Idle Kit - 600
High Idle Kit RAM 1500 2014-2022 3.0L EcoDiesel / Dodge RAM 2500-3500 2007-2022 5.9L-6.7L / Chevy-GMC 2500-3500 2020-2022 Duramax - 1036622 (bddiesel.com)
Norweld Deluxe Weekender Tray, boxes, water tank, etc - 14K plus installation
Norweld Full-Size 7 Foot Bed Tray - Main Line Overland
Carli Dominator 3.0 3” suspension system – Over 16k invested in parts, plus installation
Carli Dodge Dominator 3.0 Suspension System – CJC Off Road
Carli Torsion Sway
Carli Opposing stabilizer with diff guard (high mount and low mount)
Carli Full progressive leaf pack HD
Carli Long Travel Airbags
Carli Front Hydraulic Bump Stops
Carli Lifetime balljoints
Carli Heavy Duty Control Arms
Carli Adjustable Trackbar
Font Axle Truss
BD Diesel Pitman Stabilizer
WARN 16.5 TI-S - 3K
16.5ti-S Heavyweight Winch | WARN Industries
ARB Deluxe Bull Bar winch bumper – 3.3K
ARB Full Deluxe Modular Winch Bar Kit (Black) - 2237010 | 4wheelparts.com
AEV Snorkel with pre-filter, using RAM active-air system – 1K
Ram Snorkel System - American Expedition Vehicles - AEV (aev-conversions.com)
Mule Expedition Roof Rack, Baja Designs side lights, Baja Designs S8 40” lightbar, etc – 3K
Ram Crew Cab Mule Ultra Rack | By Expedition One (expeditiononestore.com)
Switch Pros 8 switch accessory system – 500
Rigid bumper lightbar and fog lights – 600
AMP wireless air spring controls, tied into an ARB twin air compressor mounted on the flatbed, with quick disconnects on both sides of the truck – 1.5K
Pacbrake HP10325 Wireless Air Spring Controls (xtremediesel.com)
ARB On-Board Twin High Performance 12 Volt Air Compressor - CKMTA12 | 4wheelparts.com
Titan tanks spare tire mounted diesel transfer tank 30 Gallons – 2K plus install
2013-2021 Dodge RAM TITAN Spare Tire Auxiliary Fuel System (4030213) (titanfueltanks.com)
35” Kumho Roadventure MT71 Tires and aftermarket wheels.
AMP research power deploy steps w/ODBII interface – 1.5K
https://www.4wheelparts.com/p/amp-p...d-play-kit-black-76138-01a/_/R-BGQD-76138-01A
Truck total just in parts and KBB is over 90K, with labor I spent probably around 120K+.
ASKING 69K for the truck. I am starting a new build, which is the only reason for sale.
eXpeditionXterra
Since it was asked, the RAM can seat 6 with the center console flipped up. Granted the middle passenger up front has to contend with the stick shift.
Also things I forgot:
-accessory power added to the cab for Ham radios, using rig runner low voltage disconnect and rig runner Anderson power pole fuse block.
-Console vault under the center seat, removed the CD player in favor of the gun vault.
-Weathertech floor mats.
eXpeditionXterra
What is the payload on the truck stock and then with the Carli system?
I had the pack custom built for the truck by Deaver (they make the full progressive pack for Carli). It was tuned to support the truck with a camper on it. I took the truck and camper (wet) to them and they set up the pack for that weight. The Carli HD leaf pack was tuned to have 2000lbs in the bed at all times and this custom pack is right in the same ballpark. I also have the airbags, so I couldn't tell you what it's capable of with the addition of the bags since those are adjustable on the fly. Stock payload shows 2560lbs.
The issue with looking up payload numbers on a 2013 is that halfway through the 2013 model year, they changed from leaf sprung to 4-link coil.
Roambler
Well executed. Looks like a hop to get into the camper without the stairs for quick gear and fridge grabs but the price you pay for the Offroad prowess this rig has.
H3Trex
I see a pretty nice pull out ladder in one of the first pics of the truck in the desert/lake bed. Very nice rig and fair asking price!
eXpeditionXterra
That’s right, 5 step scissor. Also have the Norweld clip in for quick grabs of stuff.
Herbie
Rendezvous Conspirator
Ooh, curious about this photo. On my just-purchased fb Hawk, it looked like the natural point where the forward awning leg would meet the body was a bit forward of where I run out of tray. (And I didn't want to attach mount to the truck body) Did that leg have to angle rearwards slightly to line up with a mounting point on the tray? Did this work OK? (Or maybe does your awning mount slightly farther aft than on my camper...)
eXpeditionXterra
It is very slightly angled to the rear.
jgrillz94
