2008 Aliner Classic - DFW
Texas TT
I ended up with one too many trailers, so I need to part ways with this one.
Asking $7300 cash. Located in the Dallas, Texas area.
Folds down for easy towing and garage storage, but sets up with quite a bit of room. Sleeps 4. Sets up in a few minutes.
Everything works. No leaks or soft spots. In fact we tend to leave it deployed on our RV pad. 3 way fridge. The AC unit is less than a year old and large enough to keep things cool, but small enough to run from a small generator (not included). Hot water heater, potable water tank, and outdoor shower. 12 V water pump, propane water heater. Also has a microwave. Fantastic fan above the stove. Brakes work good, EZ lube hubs. Hitch wiring is 7 blade RV. Brand new tires in June.
This is an 8 year old camper, and has been used. However, overall condition is very good.
There were a few items we modified.
A solar panel was added for off grid camping. I did not want the hassle of moving panels around the campsite to catch the sun, so we just went with an oversized panel. Basically it charges with a little bit of sunshine, even while driving.
The stock bumper is the weak link on most Aframes. Basically the stock bumpers tend to fall off. Instead of waiting for this to happen, we replaced it with a custom steel reinforced bumper. A 2 inch receiver was welded on to make use of cargo boxes or bicycle racks. The fragile stock tail lamps were replaced with LED units inside the bumper. The rear frame was further reinforced with a ¼ piece of angle iron.
On the inside, we also added multiple USB outlets inside with a digital LED gauge for the batteries.
A summary of the extras:
150 watt Solar panel feeds two 12V batteries through a charge controller
Upgraded reinforced steel bumper -- with 2 inch receiver
USB charging ports installed into the 12V system
LED tail lights
Matching diamond plate tongue box can hold 2 propane tanks (included).
Spare tire
Overhead storage shelves
Brand new RV Cover (still in the box)
Weighs about 1600 lbs. empty. Our V6 FJ Cruiser has pulled this to Ouray, Moab, North Carolina, and all over Texas. Tows really well.
Torsion axle. We have had it down a few fire roads, but nothing more extreme than that. This was mainly our 'campground' camper.
It has been mostly cleaned out. Any personal camping items seen in the photos will be removed prior to purchase.
Photographs:
