basicfish
2007 Jayco Baja 10Y. near Houston Texas
The camper includes an roof air conditioner, heater, fridge, indoor, outdoor shower, toilet, and 12 volt battery, it is in good overall condition, but we stored outside and needs a good detail.
some of the original Jayco propaganda
This pop-up camper has 13 inches of ground clearance, 15-inch off-road tires and heavy-duty suspension with heavy duty shocks and leaf springs. The front deck, with it's 1200-lb weight capacity holds 2 motorcycles or an ATV, with ramps included to use when you get there.
SPECIFICATIONS: Travel Length - 19.5'. Campsite Length (set up) - 20'-10in. Approximate Travel Height - 66"(74" with AC) . Unloaded Vehicle Weight (UVW) - 2375 lbs. Approximate Hitch Weight - 220 lbs. Gross Vehicle Weight Rating (GVWR) - 4550 lbs. Cargo Carrying Capacity (CCC) - 2175 lbs. Fresh Water Capacity - 23 gal. Sleeping Capacity - 4-6 people. 7 ft. wide with extended cargo area.
