Ramtiger33
07 Dodge badged 3500 diesel sprinter conversion van. Bought van in December of 17 with 90,270 miles on it. In it's former life it was a Coca-Cola refridgeration / entertainment van. We removed everything down to the metal and started our buildout. Due to weather and schedule we did the work from January to September.
LINK TO CRAIGSLIST AD TO SEE PHOTOS BETTER
**Mechanical upgrades/repairs with mile markers**
Oil/filter change, 90,400-94,800-102,300
Engine and cabin air filters, 90,400-102,300
Fuel filter, 90,600-102,300
New Struts and shocks, 90,700
AC serviced, 90,700
New front tires, 90,700
New Tow hitch, 90,800
New Glow plugs, 91,600
New Rear and spare tires, 93,300 (rotated with fronts 102,300)
New Tail pipe, 94,000
New brake pads/rotors all around,Calipers serviced, new brake fluid, new emergency brake pads, new serpentin belts, transmission fluid/filter changed, new dpf filter, new oil separator 94,476
New drive shaft, 94,700
New 225 amp alternator, 98,295 **NEW OEM ALTERNATOR PUT IN THIS WEEKEND 107,300-THE LAST ONE WAS A REMANUFACTURED MADE IN CHINA PUT IN BY A SHOP IN MISSOULA MT**
New Sheel-man heated wool/leather seats, 99,500
Undercarriage has a rubberized anti rust coating
Roof top has a partial advertisement wrap (only can see it from above)
In exterior pictures you will see sheet metal squares riveted over former speaker holes.
Also in some the exterior shots, the van is a little dirty as we have been living in it fulltime in the desert
**Buildout, everything is brand new**
Insulation, wool and ESP EZ-cool
Maxxair fan 10 speed reversible (2)
Webasto air top 2000st diesel heater with Smarttemp control
Xtend 12 1/2 foot ladder
Mono-crystal 200-225 watt solar panels (3) 600-675 total on the roof
Morningstar TS-MPPT-60 controller with remote digital display
Aims 2000w pure sine wave inverter-charger w/6000 watt surge and remote switch display
Vmax 6v 235 AH Xtreme AGM batteries (4) 470 AH total
Blue sea 12v fuse block and on/off switches
30 amp Smart Plug cord with 15amp dogbone
RV surge protecter portable EMS
Blue Sea 7622 ML-Series HD auto charging relay for charging from alternator
Smoke-carbon monoxide alarm/detector
USB charging ports 6, 12v plugs 3, some light are usb chargeable others are battery powered puck, skylight-escape hatch (Bomar boat hatch) over the bed
Six gallon plastic water jugs, (4 for fresh water, kept in garage/basement) (1 for sink grey water)
20 gallon water tank inside
Lifesaver heavy duty plastic jerry can type water filtration system (drinking)
Shurflo strainer, 3.0 water pump and pressurized accumulator tank
Bosch Tropic 3000 mini tank hot water heater
Moen kitchen faucet
Vigo Matte Stone Vessel sink 14"×19"×6"
Shower 30"×24" with SS pan, delta fixtures and extra 8' hand held hose extension for outside washing
Thetford porta pottie curve toilet
ARB 63 quart fridge/freezer
Camp cook everest propane stove
Interior cabinets are 3/4 oak plywood
Counter tops are 5/4 oak
Garage / basement cabinet 3 / 4 oak plywood
Flooring is painted Advantech residential sub floor 3/4 plywood
Fullsize Mattress is 2" of latex with 2" of wool on each side wrapped in a organic cotton cover
Bed headboard 2" foam with leatherette cover, this is easily removable
Curtains for between bed-kitchen, cab-kitchen and shower
Sliding door and back doors were left unisulated while we figured out if we wanted windows or not
The Vondo get 18 MPG all day at 65 mph while weighting around 8,400 lbs
Cabinets under bed garage/basement area can be moved easily.
Plywood in the back of headboard is easily removed, we were still trying to figure bug net or closed off.
I have more photos if needed, only allowed 10 photos for post.
We are currently in Watertown, SD. We will deliver or pick you up at a nearby airport. Heading to the north east at the end of the month.
Selling due to wanting to live full time on the road and wanting more space due to our age. Van runs great.
**Price $37,700.00**
2007 Dodge Badged Sprinter 3500
07 Dodge badged 3500 diesel sprinter conversion van. Bought van in December of 17 with 90,270 miles on it. In it's former life it was a Coca-Cola refridgeration / entertainment van. We removed...
nesd.craigslist.org
AC serviced, 90,700
Moen kitchen faucet
