crawler#976
Sold...
2006 StarCraft 10RT, the short, no deck model built for off highway use. More photos are available, if interested, I'll e-mail them to you.
This is one the best off highway popups ever built. At only 13’ 3” in length and 7’ 2” in width, it will go anywhere it will fit. With an extra heavy frame, 15” tires, and very durable construction, 25 gallon water capacity, it's perfect for remote dry camping.
http://www.kellysrv.com/img/base/starcraft/Starcraft/BROCHURE_Starcraft_2006.pdf
GVWR (gross vehicle wt. rating – lbs.) 2550
GVW (gross vehicle wt. – approx. lbs.) 1966
Base/Dry Hitch Weight (approx. lbs.) 187
Base/Dry Axle Weight (approx. lbs.) 1779
Trailer Size – closed – Center of Ball to Bumper (add 10" for spare tire & carrier) 13' 3" x 7' 2" wide
Height (closed) 67"
Trailer Length (open) 20' 6"
Fresh Water Tank 19 Gal under floor, combined with 6 Gal water heater, 25 Gal capacity
Sleeping Capacity 6
Awning 9’ and Screen Room w/Zippers
16M BTU Furnace w/Electronic Ignition
Dometic® 3-Way Refrigerator – 1.9 cu. ft.
RVQ® Carryout Gas Grill
Bunk Fan Lights w/ fans
Battery Gauge
AM/FM Stereo CD w/Outside Speakers
Duo-Therm™ Air Conditioner
Electric Brakes
Double 20# LP Tanks w/Auto Regulator
Outside Shower
Three New C rated 235/75-15 M/T tires
Sears DieHard Platinum Group 31M 1150 Cold cranking amps, 205 Minute reserve capacity
RV King front mattress w/2 Kamp-Rite Single Self Inflating Pad 77 inches long by 31.5 inches wide x 4” thick, over 2” medium density foam. That's 6” total thickness, the maximum allowable to close the roof. Very comfortable and adjustable.
RV Double rear factory mattress
We have repaired one seam on the plastic window material on the large window/screen near the dinette. The window no longer opens fully, but it is 100% seam sealed and solidly stitched. There is one screen patch on the front screen.
The aluminum diamond plate front and rear has been coated with tan rattle can bed liner. The trailer has been used for it's intended purpose, and even with huge mud flaps on the truck, there are stone chips on the frame and all other exposed underside metal surfaces.
Sold...
Optional items at additional cost:
Thetford Porta Potti® Campa Potti™ XT $120.00
Trekker Fold-A-Privy $55.00
Goal Zero 60W solar system w/ charge controller $250.00 (over $400.00 in parts)
Height (closed) 67"
Sleeping Capacity 6
Battery Gauge
Electric Brakes
Outside Shower
Sold...
