2006 Jeep Rubicon LJ - LS Swap, Atlas, Dynatracs, SOLD
SOLD
Bottom Line Up Front: 2006 Jeep Unlimited Rubicon LJ - LS Swap, Atlas, Dynatracs, etc. - Interesting Trades considered
Sorted, highly modified rust free last-of-the-LJs. In Southeast VA
Base truck: I am the 3rd owner. 2nd owner did an initial build. I purchased in 2014 with 80k miles. This is an inland southern LJ (North Carolina and Virginia). It has never seen salt, either winter or beach. NO rust. Dual top Rubicon. Not a lot of Jeep left, but what is there is pristine. 98k miles when it became more GM than Mopar. 3300 miles since conversion
Engine: 2010 Silverado L20 4.8 liter Vortec “LS”. 87k miles.
Why 4.8? I needed a Gen IV engine to talk to the 6L80. The 5.3 in this generation have the “active fuel management” cylinder deactivation, which is causing a lot of lifter issues. The 4.8 has the variable valve timing without the AFM and associated problems. A 6.0 is the classic swap, but with the low lift, tight exhaust clearances, and an attempt to maintain reasonable fuel mileage for overlanding, the 4.8 was a more balanced choice. 295HP/295Lbft, plenty for a rig actually used offroad. Engine was pressure tested in spec. Still cross hatching in the bores. New water pump, starter OEM. New plugs, wires, valve cover gaskets. New current Gen Camaro oil pan; 8 quart capacity, better clearance than truck. Air intake was repurposed from the LJ OEM - Paper filter, available at NAPA, no worries about dust infiltration with aftermarket cone style. Speartech Wiring harness. Wiring pigtails remain in the wiring harness for post-cat O2 sensors and purge system. Currently, codes defeated and no post-cat O2 sensors in place. GM charcoal canister was also not utilized, as I did not have to pass emissions. Bottom line, I made this truck capable of a full emissions set-up, but chose not to do it. ECU is GM only. HP tuners mild tune, still runs on 87 pump gas. Mainly tuned to eliminate the early 5th and 6th gear entry on stock tune.
Exhaust: Hooker cast iron headers, ARP header bolts and flange bolts, Custom “Pie cut” 2.25" stainless exhaust. Catalytic converters and resonators on both sides. Single stainless muffler, single 3 inch exit. Resonator in the tail section due to a drone at 1900 RPM on initial run.
Transmission: 2015 Silverado 6L80 - 30 (yes, thirty) miles at install. IIHS crash center is near me. This trans came out of an offset collision crashed truck for federal testing. 2 fluid changes already as we had to pull the TCU, and then a second done as part of shakedown. Remote cooler with fan, Custom linkage that uses the stock TJ cable and shifter. Tap shift works. Key for offroad technical use. Toggle switch in low dash for right hand tap shifting.
Transfer Case: Atlas 4 speed dual transfer case (New for build). 2.0:1 and 2.7:1 ratios. Can be combined to 5.4:1. With 6L80 gearing, above ratios are almost identical to both the original Rubicon 4.0:1 case (the 2.7) and stock Jeep 2.7 ratio (the 2.0). 123:1 ratio when the cases are doubled and in 1st on trans.
I find the combo to be excellent at various duties. 2.0:1 is great for higher speed trails, 2.7 for more technical terrain. I’m not really a rock crawler, and Vermont trails tend to be wet enough that some momentum is necessary, so the doubled 5.4 is fun but not terribly useful. Would be fantastic in true rocks or out west.
1310 output on the front, Rubicon flange rear.Tummy tuck custom crossmember, nearly flush with the frame rails
Driveshafts: Tom woods, 1310 joints. Spoke directly with Tom about this. Much better articulation with 1310 vs 1350. Power of 4.8 well matched. He specifically told me not to order the 1350, and would replace my 1310s if I could break them. They are great, no balance issue at 80 mph on the highway.
Axles: 5.38 ring and Pinion
Front - Dynatrac Hybrid 44/60 5x5.5. 63.5 WMS, Center pumpkin and R+P are the JK 44. ARB Locker
Remainder Dana 60 one ton with 35 spline shafts, 1480 U joints. 13.25 inch dual caliper brakes, 17 inch wheel required. Dynatrac prosteer ball joints - rebuildable in place; Dynatrac “stub hub” locking hubs - 4 inches less per side for improved clearance
Rear - Dynatrac Dana 60 High clearance Semi Float 5x5.5, ARB locker, 35 spline axle shafts, 11.25 inch disc brakes
Completely bullet proof, serviced after initial 500 mile run in and after every trip with a water crossing. Front bearings also repacked after most recent trip, pristine with no water infiltration
Suspension: Intentional low COG build. 3 inch lift, 1 inch body. AEV/Nth Degree 3 inch lift springs, Savvy aluminum control arms, Ballistic fabrication control arm joints. Fox 2.0 remote reservoir shocks, JKS quick release front sway bar disconnects.
Steering: Currie Correctlync TJ system; PSC TJ steering gear; Stock Silverado PS pump
Brakes: As above, 13.25 discs front, 11.25 rear. New master cylinder from Dodge Durango, appropriate piston size for larger calipers. No ABS (Did not come on stock Rubicon)
Cooling: New custom TJ to LS All aluminum custom radiator, Superior Radiator, Michigan. SPAL 16” 2025 CFM electric fan
Currently wired with traditional block sensor and relay for simplicity. I also have a DC control solid state variable controller that was initially on the jeep I will include with the sale. Fan is quieter at partial speeds. Drawback is there is a temp sensor that mounts in the radiator. Worked well. I took out for one less failure point while wheeling.
Large external Trans oil cooler with separate 2000 CFM fan. No cooler in the radiator to avoid coolant catastrophe with trans.
AC - new Sanden compressor, custom lines and new condenser. Runs from stock Jeep controls. All HVAC dash controls work as they should.
Fuel: Genright 31 Gallon aluminum Safari tank with steel skid; New OEM Mopar fuel pump; New fuel lines tank to motor, inline filter outside of tank for easy maintenance. II Much VSR vent system on the vent lines.
Armor: Savvy aluminum front and rear bumpers; Metalcloak Arched highline front fenders; Custom ventilation in fender panels; Genright aluminum rear fenders
Mopar tube rock rails; Undercover fab aluminum engine skid with mods for LS; Undercover fab T-case aluminum tummy tuck skid with custom welded aluminum crossmember for Atlas and trans. Custom bent front grill hoop/guard. Plate steel steering box skid; Front recovery hooks; Rear recovery point at 2” receiver; Genright stock thick steel fuel tank skid
Complete coverage front to rear.
Wheels/Tires: Method “fake beadlock” 17” rims 5x5.5. Say what you will about fake beadlocks. They weigh far less and are easier to balance. The rock ring does a great job of protecting the bead. Some scratches on the rings, very presentable. Cooper 37x12.5 STT pro x 5. No chunking or sidewall damage.
Interior: Complete dynamat coverage from firewall to tailgate; Bed Rug vinyl carpet replacement; Between the two above, very quiet for an LJ
Poly performance full roll cage; Standard Rubicon seats with no tears; Carharrt seat covers
Center console subwoofer, Sony single DIN head unit with bluetooth
Hot heads full headliner on the hard top. Much cooler and quiter
Dakota Digital Full Gauge system, including gear indicator, trans temp, etc. Completely eliminated the Jeep computer and gauges/interface.
Miscellaneous: Warn 8000 winch with synthetic line; Trucklite LED headlights; Poison spider hood louvers; Exogate spare tire carrier. No issues with the 37” spare; Full hard top and doors with no issues; Half steel doors and soft top, no issues though the top has been stored for a couple of years; Set of soft half doors; Safari bikini top; Rear seat not installed but goes with it.; There is an electrical kill switch, hidden, as a theft preventative device; New Odyssey battery this spring;SPOD for lockers, compressor, trans fan.
I’m sure there are a few loose ends I have forgotten, but you get the picture.
You’ve read this far, so here are some more details. I built this as the “pinnacle build”, and you might say it was an arms race of sorts. My Son and I competed in the Vermont Overland Trophy 2014-2018, and every year we were a little closer. Long story short, we won 2018 with the LS converted LJ. Great story, great time.
The conversion started out as a project my brother and I were working on. He has done 6 other conversions, diesels and LSs, so was no stranger to these. He builds $2 million dollar boats for a living, wiring as a specialty, so everything is clean. We got the motor in, got it running, but ran out of time. I then sent it to Wilson and Steely Kustom Coachworks in Athol MA. Steve Wilson, the owner, said it was the only partially finished project that he ever took in where he didn’t simply start over from scratch. I’ll take that as a good sign. We took delivery and won VOT.
Why sell? It’s sorted, it’s essentially a brand new indestructible LJ? Mainly it’s because the chapter is over. VOT was shut down, I don’t need quite this much rig anymore. My son has his own Tacoma now. I would like to back off into the realm of 33” tires and not quite this much jeep.
I would consider partial trades for built, rust free overlanding rigs that are a bit more overland and less rock crawler. Tacoma, land cruiser, fully sorted land rover. Maybe a JK with Ursa Minor set up. Other oddballs might catch my interest. Pinzgauer, nice series truck. Try me, worst I can say is no.
Edit - more pics added below. Even more at: https://navydivedoc.smugmug.com/2006-LS-LJ/n-K8sKRt/
Rinzlerz
