Michael Brown
You followed me, so now we're both lost
I have had a coolant leak coming from my water pipe o-ring for a while and decided to try to fix it. I had ordered o-rings and removed the manifold only to find that I had gotten o-rings for the wrong pipe.
I had ordered the o-rings [N10] for the bypass pipe [9] and not for the pipe in the water pump housing [12]. I replaced spark plugs and put it back together without changing anything, but now the leak is severe enough to leave a puddle under the truck (before there was only some on the block).
Does anyone have the OEM part number (or correct size) for the [13N] o-ring in the back of the water pump housing?
