Aaron Wasson
In the rear with the gear
Im more of a lurker on EXPO than a poster, but Ive decided to put my Rover up for sale so that I can look at getting a Tacoma. It took me some time to actually find this vehicle when I started looking. Everything on it works and the headliner is still attached! Kinda hard to say that when it comes to a Discovery.
Im asking for $15,000 but will take a good offer. Im located in Houston, Tx, but I am willing to take it a reasonable distance if needed.
Full rundown:
I didnt get any information on what the previous owner had done to the vehicle, so maintenance was done (heavily). Im guessing that the previous owner was a soccer mom (I found a nail file stuck under the rubber mat near the gear shift).
Preventative Maintenance:
Drained front and rear diffs - Replaced with Royal Purple 75w/90 gear oil
Drained transfer case - Replaced with Royal Purple (transfer selection lever was actually stuck like it had never been used)
Drained Transmission - Replaced filter and gasket and I replace the fluid every 20k miles
Brake Pedal was mushy - Cleaned out the reservoir and bleed the brakes twice (finally where they should be)
Oil - Changed every 3k miles with an extended size filter and Rotella T-6 (tires rotated at same time)
Replaced radiator - began getting a small pinhole leak near a mounting bracket so I replaced the radiator and flushed the system 3 times. Coolant is the required HOAT.
Modifications:
(Note: all parts ordered through Atlantic British or Lucky8 LLC)
3in TerraFirma HD lift w/ 2+ Terrafirma Shocks
Terrafirma Caster Corrected Radius Arms - New Bushings were used for the Arm-to-Axle and Arm-to-Chassis
Terrafirma Adjustable Track Rod - New Bushings
Rebuilt Steering Gearbox - factory one was leaking fluid and eating bushings and had a dead spot
RTE HD Steering Draglinks - Solid Stainless steel links - designed not to bend on trail - replaced all tie rod ends at the same time
New Ball Joints
Rebuilt Front Driveshaft - all U-Joints were replaced with grease-able joints (must on a Discovery)
255/55/18 Nitto Terra Grapplers
Added towing package
About Vehicle:
I can tell you anything you would want to know, so just ask!
If more pictures are needed, just let me know!
Full rundown:
Modifications:
New Ball Joints
About Vehicle:
