Up for sale is my 2001 Toyota Tundra, 4x4, V8, TRD, Limited with a Roamin' Chariot popup camper. The truck has just under 250k miles on it, I've recently put a bunch of work and money into the truck. Timing belt, water pump and pulleys replaced at 220k, I just had a mechanic replace all 4 shocks with KYB ajustables, valve cover gaskets replaced, full rebuild on rear axle: new bearings, seals, brakes, drums turned, etc., driveshaft carrier bearing replaced, two new front cv axles, ac re-charged, i replaced the carpet with a new one and put newer seats in as the originals developed some wear. The truck has bfg allterrain tires, 3 of them have about 60% tread left and one has about 1k miles on it, the spare is also bfg allterrain. The wheels are pro-comp. The truck has front and rear hitches with the tow package and firestone airbags in the rear. The body has dings and scratches, but no rust anywhere as was a California vehicle most of it's life. The windshield has cracks and would need to be replaced, the cracks are lower so hasn't bothered me too much.
The camper is a Roamin' Chariot, with a Westfalia style pop-top. I gutted the camper, re-wired and installed new FRP wall and ceiling panels. The pop-top canvas was removed and all the zippers replaced, most of them work great, one or two get stuck from time to time. I installed new LED lights and replaced the carpet and flooring. I made custom cabinets to facilitate a Dometic sink/propane stove with 5 gallon fresh and grey water tanks and a second cabinet to house the auxiliary battery, fuse panel, inverter, solar charger and some extra storage. Above the cabinet is a Dometic fridge. The camper is not electrically connected to the truck and relies on two roof mounted solar panels to keep the battery charged. Also above the kitchen area I installed a dome vent with fantastic fan.
$11,500 obo, call, email, text 406-830-5266
Truck is located in the Bitterroot valley just south of Missoula, Montana.
