I've been doing some thinking about the air suspension on my 2010 QX56, and I wanted to run my thought by some other people to see if I'm missing something. I like having the air suspension in the truck; it rides nice, and obviously adapts the truck to different load outs. My thought though was; as prone as the stock system is to fail, why not replace the air shock with a nice adjustable shock from Bilstein or Fox or one of the better brands, and then replace the coil spring with an air spring from airlift or another reputable brand. This seems to be how many of the newer "high end" air systems are setup. Now obviously the problem is that if your airbag gets a leak then the whole truck will sink down to the bump stops, but it already does that if the air shock goes bad. The spring location seems more protected, and those types of airbags seem to be much more heavy duty. Thoughts?
