1998 Proportioning Valve
Salonika
Monterror Pilot
Anyone have a good source for a new proportioning valve? I see some on eBay but I’d rather source from a reliable certified retailer.
Salonika
Monterror Pilot
I have never known of a failure with them.
So the seals inside must go bad eventually…..I mean mine is 24 years old. They have that lever with the spring attached to the body, that moves a piston / plunger inside the valve body, it must have similar characteristics to a master cylinder. Eventually it will fail when the seals inside fail. One of those seals prevents leakage to the outside since it’s the plunger that moves depending on cargo load……
jgrillz94
