1997 Land rover Discovery SE7 W/ Off Road modifications
borg1087
I am selling my beloved Disco because we need a truck. It has 145,000 miles on it. I have rebuilt and replaced almost everything on it. There is some rust in the usual places, rear wheel arch and drivers floor board. Drivers floor board has been fixed. The clear coat is coming off the hood next to where the black paint was applied. I have taken very good care of the Disco. It is surprisingly leak free ish. Interior has some wear, however no rips or tears in the seats. Power everything works, including seat heaters. A/C is cold. Cylinder head gasket were done less than 5,000 miles ago, at that time the cylinder heads were gone through and a valve job was done. The Goodyear Wrangler Duratrak tires have 800 miles on them. I've used this rover for mountain rescue in Colorado and it's never let me down. Please let me know if you have any questions. (The pictures are changing orientation when I upload them. I have them corrected and many more available.)
Brett 719-510-8080
$5,000
Modifications:
Terrafirma shock towers
OME Heavy duty suspension kit
Bilstein steering damper
Smitty XRC10 winch
Front and rear differential guards
Tactical Rovers front bumper
Columbia Overland rear door plate W/ axe, shovel and fire extinguisher
6 Led flood lights
Factory Land Rover roof rack and rear ladder
Pioneer iPhone/ android ready head unit
Custom rear cargo shelf
95w/115w headlight bulbs with relays
Back up flood light on roof rack
Factory Land Rover rubber mats
Maintenance / replacement parts in the last 5,000 miles:
Fresh oil chance, transmission flush, driveline fluids
Rocker shafts, arms
Camshaft, cam sprocket, timing chain, lifters
Oil pump and oil cooler lines
Rod and main bearings
Transmission cooler lines
Steering box
Water pump, thermostat, serpentine belt
Recored brass radiator
Fan clutch
Brake master cylinder
Brake calipers and pads
motor mounts
Complete exhaust system
Oxygen sensors
Throttle position sensor
Idle control valve
Remote key fob (works)
Spark plug wires
Spark plugs
borg1087
I appreciate that. I love the rover and done some great things with it. I'm sad to see it go but any have room for so much.
jgrillz94
