1996 Lexus LX450 Turbocharged in Phx. Az. USA
1996 Lexus LX-450, (Land Cruiser) Turbo-Charged with water to air intercooler, 5.29 R&P. 219K Miles. Head Gasket replaced @200K, Head was ported and polished in anticipation of turbo install which was installed at 210K miles. Injectors serviced, new water pump, etc. Turbo is HolsetHX35 (same as used on Cummins 5.9). Turbo was purchased new. Adjustable waste gate currently set @7psi so works well with factory ecm. HD Fan clutch mod. Ultra-Gauge, Boost Gauge, AFR Gauge, Tranny temp gauge, Full 3” exhaust, and new Magna-Flo Muffler, and Cat.
Mobil 1 oil every 1,500-2,000 miles, tranny pan (4 qts) every other oil change.
Dino for T-case, and diffs once a year. (5-7K miles per year ave.) AC blows cold. Everything works as it should.
Cruiser Outfitters’ 10% Over drive, as well as 3.1 to 1 Low Range Transfer Case gears. (Parts alone $1500) installed by Camelback Toyota in Phx.
Cruiser Outfitters Steering arm (RH Steering) for adding Ram Assist
Factory lockers, as well as Ctr. Diff lock. HD tie rod and ends. Front CV Driveshaft. All breather tubes extended up into engine compartment.
White with tan interior, absolutely no rust. Power driver and pass seats are 2007 Honda Accord. (Orig. seats including factory 3rd row) are included). All interior lights are led. (Pfran).
4” Slee lift, Slee Short Bus front bumper, Warn XD9000i Winch, 37x12.5x17 Cooper SST (1,000 miles). Spare has never touched the ground. 5-New 17x9 Black Rhino wheels.
Slee Sliders, Slee headlight wiring harness, New DEPO headlights, and LED taillights. Aux. electric fan. Rear upper and lower bushings replaced this past summer, as well as new tie rod and TRE’s. Presently has Toyota front grille as the Lexus grille won’t work with the Depo headlights. (Lexus grille included).
Kaymar Rear bumper with swing out tire carrier on right. Dual 5-Gal.gas can swing out on left.
HD Roof Rack with fold up 4” Sides. When folded down rack is only 2” above roof line, so fits into garage easier. 81-1/4” to top of rack with tires @36psi
Puma Air compressor. New 1500-watt invertor, New Odyssey starting battery, Platinum Plus auxiliary battery mounted in rear to power compressor and invertor with 2 ga. charging wire from main batt. with 150-amp re-settable breakers both ends.
63 Qt Edge Star refrigerator/freezer. Interior attic storage rack.
Cobra CB Radio with tuned antenna
Hi-Lift Jack on custom mount for easy access.
Always stored in garage when not in use.
150 Amp Alternator kit (not installed)
Spare front drive shaft. (Non-CV)
Only known issues:
Has a couple small dings on driver side rear door, and pass. front fender.
Also drivers side sun visor sags, well known problem. haven't had time to pick up a LX430 from the pick-n-pull
Asking $22,500 located in Phoenix, Az.
Have lots of high res. shots that I can email or text.
Thanks for looking...Bob 623-670-1270 text.
Got pics to upload
WonaWarrior
