1992 Landcruiser VX Limited Diesel - $12000
fisher205
https://rapidcity.craigslist.org/cto/6100660807.html
1992 Toyota Landcruiser Diesel VX
VIN: HDJ810023877 (ebay does not recognize Japanese VIN)
1hd-t engine, big / bottom end bearings just changed with new "torque to yield" main cap bolts, have receipts, injector pump was rebuilt, new fuel filter, new valve cover gasket, new timing belt and accessory belts, receipts for all
Transmission was rebuilt and just got flush and filter / gaskets replaced, shift points adjusted (correctly) back to stock
All factory parts ordered from Radd Cruisers in Vancouver B.C.
Power everything
Suede seats
141,000 miles
ARB bumper
2.5" OME lift
Full floating LSD rear end
Front axle is good condition
Center locking diff only (not front and rear electric lockers)
Working factory fridge in center console
Comes with all the window rain shields from Japan
Comes with full 1hd-t factory service manual
Also full factory transmission service manual
Power is great, easy 22mpg diesel, 500km+ range on a tank
Imported from Japan to Canada to USA. Clean South Dakota title
Everything works as it should and all the repairs and maintenance above was completed within the last 100 miles. Work performed by a certified Caterpillar diesel mechanic.
Truck is ready for the next 100k+ miles
Passenger (left) side rear door has a bit of rust (rain hole was clogged with debris)
Does not have factory front and rear electric diff lockers (center locker only)
Possible interest in Porsche's or land for trade
jmurdock
