1992 Isuzu Pickup - ARB Expedition Vehicle - Oregon - $10,000
montypower
Adventure Time!
1992 Isuzu Pickup 4x4
Most Unusual, Fully Outfitted Isuzu in the WORLD!!!
ARB Expedition Adventure Vehicle!
Located in: West Linn, OR
Peter: 503-888-6967
Price : $10,000
Basic Specs: 1992 Isuzu Pickup, 158K Original Miles, 3.1L V6, 5 Speed, 4x4, 6ft Bed, Clean/Clear Title - All lights, switches, buttons, levers work properly. It's an older truck but overall good condition, extremely reliable, go anywhere vehicle.
Upgrade Short List: ARB Lockers Front/Rear, 2.5" OME Suspension Lift, HD Tie Rods, Warn m8000 w/ Wireless & Synthetic, Big Brake Upgrade w/ SS Lines, CB & Alpine CD, Rebuilt Axles, BFG KM2 33" Tires, 15" Alloy Wheels, 4.56 Gears, Winch Bumper, Exo/Rack, Rear Bumper w/ Receiver, HD Torsion Bars, Optima Yellow Battery, 3 to 1 Tcase Gears
Read Full Build: http://gitout.com/showthread.php?23-1992-Isuzu-Pickup-4x4-V6-ARB-Expedition-Build-Little-Gray
Watch 4WD SLOW Video: https://vimeo.com/36176264
Watch past off road trips: http://www.youtube.com/gitoutoffroad
Warn m8000 Winch New - $650*
5/16" Amsteel Blue Synthetic Winch Rope 80FT - $170
ARB Series III Simpson Roof Top Tent - $1,500
Brand new cover installed today!!!
ARB Tent Setup!
15x7.5" Alloy Isuzu Snowflake Wheels (light weight) matching spare - All New Lug Nuts Locking - $300
150K - 02/29/12 - America's Tire BFG KM2 33x10.5" - 5 Tires w/ Free Replacement Certificates - $1,130
Revenge Fab - Exo Cage / Roof Rack (for roof tent) w/ 4 mounts for off road lights - $1,500
Complete Thule Bed Rack: Quick release Base Rack, 2 Thule Bike Racks w/ Locks - $1,000
2 Jerry Cans w/ Bed Mounts + Cable Locks - $150
X-treme High Lift Jack 48" w/ handle holder + Protection Boot - $150
Roll Cage Jack Mount - $25
Bed Tool Box - Diamond Plate Used - $100
Spare tire carrier w/ Full Size Spare - $300
146K - 10/01/11 - OME HD Springs, OME Greasable Shakles, OME Shocks, OME Bushing Kit, OME U-Bolts - $1,100
SKS Rear Axle Bearings, SKS Inner/Outer Front Axle Bearings (all replaced) & Rear Bearing Install - $320
Mobile 1 Synthetic Grease, Axle Seals Inner/Outer Front/Rear (all), Gear Oil - $100
NAPA Rear Axle - Rotors, Brake Pads, Calipers - $220
Revenge Fab - Winch Bumper, Rock Sliders, Rear Tube Bumper w/ Receiver Hitch - $1,500
Fenders front/rear tubbed to eliminate tire rubbing at full compression - $300
Truck sits approx 3/4" taller in the rear. Rides level with 500lbs of camping gear in the bed.
Roll cage wraps around front + side of tent to deflect tree branches and protect it off road.
Off Road Light mount tabs!
montypower
Adventure Time!
Indy4x - SS Brake Line Kit, HD Torsion Bars, Pro-Comp Steering Stabilizer - $500
143K - 08/18/11 - Steering Gear Box & Install & Alignment - $350
NAPA Front Axle - Rotors, Calipers (BIG Rodeo ones), Ceramic Pads, Brake Flush - $280
NAPA Upper & Lower Ball Joints (nice ones) all replaced - $360
Indy4x - Heavy Duty IFS Tie Rods & Joints - $290
Wheel Alignment - Line Up Shop - $55
OEM CV Boots Replaced (driver side) - $75
All windows seals and door rubber is good! No leaks. No noises.
Factory Bench Seat (great condition)
Factory tire jack located behind the seat (works great).
Cobra 18 WX ST II w/ Weather Scan - Hood Mount - Wilson Flex 3' W3FD-B Antenna - $150
Alpine CDA-105 w/ USB & iPod & Aux Input - Apline 4" Speakers - Wiring Harness - $250
(all wiring properly soldered and heat shrink wrapped)
Window Tint - SunTek CarbonXP 35% - $140
Clean Original Carpets!
ARB Compressor, Switches, Actuators, Fittings, Air Line Kit - $400
ARB Lockers Front/Rear w/ 4.56 Gears - $2,000
158K Original Miles!! Low for the year. Ready to drive another 100k!
Original Isuzu Floor Mats + All Weather Floor Mats - $20
137K - Transmission Redline Man Fluid & 5w30 Royal Purple Tcase - $70
138K - Isuzu Dealer - Driver Door Hinges (upper/lower), PCV Valve, Upper/Lower Radiator Hoses, Flush Radiator - $160
143K - NGK Spark Plugs - $12
150K - Cat back 2.25" exhaust (mounted for high clearance) - $225
151K - OEM Steering Idler Shaft - $180
152K - Clutch mater & Slave Cylinder - $80
152K - Serpentine Belt + OEM (dealer) tensioner pulley - $165
154K - Exhaust Manifolds - replace all studs, bolts, gaskets - $150
154K - Spicer U Joints (all), Royal Purple 5-30 Tcase & Trans, factory ebrake cables & Gear Oil Change - $325
Exedy Clutch Kit (complete) & New Flywheel - $250
Rear main seal, transmission input / output seals (oem), O2 sensor - $100
Revolution 3.07 to 1 transfercase gears (for slow 4wd crawl) - $1,000
Optima Yellow Top D34/78 - $200
Revenge Fab - Tcase Skid Plate, Reinforced Front Skid, Custom ARB Compressor Mount - $250
Warn Wireless Winch Controler - $150
Clean/Clear Title, Original Isuzu Key, Bed Box Key & Thule Lock Keys + Huge pile of reciepts!
This has been a "no expense spared" project. Everything was done right with quality parts. It's an extremely capable, reliable and fun adventure vehicle.
I drive the truck everyday. And it's been on many camping trips including Central Oregon, Canada, Northern California, and Washington. The truck has never let me down and runs very well. I've used 1,300 gallons of fuel while I've owned the Isuzu. Lifetime average fuel mileage 17.54 mpg. Best 21.16 mpg. Truck loves to cruise at 2,200-2,300 rpm generally drive 58-63 mph on the highway for maximum fuel mileage. Travel range is over 350 miles with the extra fuel (jerry cans).
This has been a fun project and solid, reliable truck. I'm very happy with how everything turned out. This is a push rod engine so there's no timing belt to change and it's so simple. Throttle body injection with lots of room to access spark plugs and everything else. Alternator is at the top of the engine. Much nicer than the new vehicles.
My relatives have a 1992 Isuzu Rodeo (same drive train and chassis) and have over 260k on the original engine and transmission. I've seen these trucks with over 350k miles. These are tough trucks if you take care of them. I'm selling to downsize to 1 vehicle and start the next build project.
Everything you see is included.
Over $19,000 in Receipts. And countless of Hours of Labor.
Peter - 503.888.6967
hankgs
I can personally atest to the 1992 Isuzu product line. I bought a '92 4x Rodeo new in 91, and I put 80k miles on it. Many were down in Baja towing a tent trailer- I sold the truck to a fellow firefighter with a growing family, he drove it for many years and put another 60k on it; HE sold it to another firefighter who is the cheapest bastard I know! He has been driving it for the last 8 years and last I checked it had 210K on it....NEVER ONE ISSUE! :Wow1: Just oil changes, tires, brakes, spark plugs and tranny fluid...I should have kept it!
GLWS- Awesome truck!
WonaWarrior
