patrolman
Located in Denver, CO metro area.
After 7 years and countless miles, it is time to part ways with this unique rig. The trucks are rare, difficult to find, and in high demand. It gets looks everywhere I go, and on many occasions people have asked to take photos of it.
The truck has performed flawlessly for us, never had even a minor issue on long trips, and always starts. We have done road trips up to 1,000 miles fully loaded with camping gear. We simply don't drive it enough to really need it anymore. It runs and drives nicely considering the age and mileage. I wouldn't hesitate to jump in it and drive it anywhere.
Factory Features:
-Seats for 5 people
-4 cylinder engine (20 mpg) - was originally a 22rte turbo engine, now a 22re non-turbo
-R151F 5-speed manual transmission (lowest 1st gear offered; only offered in 1986-1987 turbo pickup trucks)
-4wd with 23 spline gear driven transfer case (strongest t-case offered)
-Power steering
-Air Conditioning (complete but does not blow cold)
-SR5 gauge cluster (tachometer, oil PSI, alternator, temperature, etc)
-Manual locking hubs
-6 foot long bed
Modifications:
-Slight suspension lift (approximately 1 inch)
-"Zukmod" rear suspension for heavier loads - approximately 2,000 pound capacity
-Front bucket seats from 1990 4Runner (lumbar adjustment and tilt headrests)
-Shoulder harness seatbelts installed in rear (Poison Spyder seat belt bungs)
-Center console from 2006 Toyota Prius (front and rear cup holders and storage)
-Aluminum double row radiator
-Mobi-Arc alternator stator upgrade
-Front turn signals converted to parking lights (allows for winch bumper)
-Headlights converted to accept H4 style bulbs (bulb fits in rear of light)
-Brake master cylinder converted to the larger bore V6
-Front calipers and rotors converted to larger V6
-Sony stereo (CD player, mp3 input jack, USB input)
-Rear tube bumper with 2" receiver hitch
-Bed aluminum diamond plate tool box with keys
-Locking gas cap with keys
-Plastic bed liner
-16" Toyota T100 wheels
-Tinted windows (tint is showing the age)
-Ford side mirrors
-Rear view mirror with anti-glare lever (this was optional in 1986)
-Chrome side steps
-Speakers installed in doors (marine grade water resistant)
Maintenance since I have owned it:
-Ball joints, tie rod ends, pitman arm, and idler arm replaced.
-4-wheel alignment
-Tires balanced
-Metal tire valve stems
-Engine front crank seal replaced
-Water pump replaced
-Transfer case rear seal replaced
-Driveshaft carrier bearing replaced
-Brake fluid change
-New exhaust tail pipe and radiator
-Front wheel bearings cleaned and re-greased
-Front brakes replaced
-Rear brakes inspected and adjusted
-Starter rebuilt
-Transmission fluid
-Transfer case fluid
-Rear differential oil
-Front differential oil
-New aluminum radiator and hoses
-Antifreeze change
-Water pump changed
-Fan belts changed
-New clutch master cylinder, slave cylinder, fluid
The truck is 33 years old and has over 200,000 miles, so there are items that need attention. Here are the most obvious points in my opinion.
-Headliner and b-pillar interior is deteriorating. It was covered in a soft felt material when the cab modification was done, and the material simply wasn't very durable.
-Paint clear coat is peeling - unsure if it is worth worrying about
-Small exhaust leak in the middle section of the exhaust. Small section of exhaust needs repaired.
-Power steering fluid has not been changed recently
-A/C needs a leak fixed and re-charged (possibly convert to R134)
-The clock in the dash is missing - has been missing since I purchased the truck. The stereo has a clock, so it really isn't necessary
-Tires probably have about 10,000 miles remaining and will need replaced within a year or so.
Included is a Haynes repair manual for the truck and a Toyota FACTORY service manual for the R151F transmission (hard to find).
Since the truck is a 1986, it is now 32 years old and qualifies for collector license plates in Colorado.
Clean title in hand. Emissions test will be provided for Denver Metro residents. Sold as-is and where-is. Cash transaction or cashiers check issued at the counter of your local financial institution.
Factory Features:
-Seats for 5 people
-Power steering
-6 foot long bed
Modifications:
-Plastic bed liner
-Ford side mirrors
-Chrome side steps
-4-wheel alignment
-Tires balanced
-Brake fluid change
-Starter rebuilt
-Transmission fluid
-Antifreeze change
-Water pump changed
-Fan belts changed
